Problems With Time Lapse
2393 19 2017-9-30
DroneGuyEd
Flight distance : 1168140 ft
I am seeing consistent problems trying to use time lapse with an iPhone 7.  Most of the time NO video results at all.  If I set it up and start it, and come back in say 15 minutes, the screen is locked and the app not even running.
Anyone else seeing these issues?
2017-9-30
Indian
Norway
I am a novice with the Osmo Mobile. I use an iPhone 7. I see the screen dimming to about half strength, I suppose to save power. Have you tried uninstalling the app? My first use with iPhone was eventfull. Only today it worked as it should after I updated the firmware.
2017-9-30
DroneGuyEd
Will give that a try later.  Ive seen more than a few cases when pictures or videos disappear.
2017-9-30
This is not normal, iPhone 7 is compatible with Osmo Mobile.
Please keep us updated if the problem persists after reinstalling the APP, and please try other mobile devices to do the troubleshooting as well, thanks.
2017-10-1
DroneGuyEd
WIll try later today with the resinstall.  This has been occurring for some time now.
2017-10-2
calicartel
Banned
India
2017-10-2
DroneGuyEd
Same result.  Set it up for a 30 min time lapse.  Started it and walked away.  Checked back after some time, screen is locked and app NOT running under neath.  No video shows in Editor/Browse area.  I saw similar resu;ts on vacation a few months ago.  Did a number of PANO shots.  None ever showed in in Editor area.
Make this pretty much useless.
2017-10-2
DroneGuyEd
I have also tried other mobile devices...same result.  Its just not reliable at all.
2017-10-3
los0325
DroneGuyEd Posted at 2017-10-3 05:10
I have used an Iphone 7+ and had the issue where photos went away after one day, so i got into the habit of downloading the images right after i capture them, i have not any issues with videos, im know using with an Iphone8+ ill let you know
2017-10-3
DroneGuyEd
Mine never appear at all...completely MIA.  If I could return this unit now...I would. Just not reliable at all.
2017-10-4
jeffbake
Flight distance : 955587 ft
I only use the DJI Go app with the Osmo Mobile for motion timelapse with an iPhone SE since that is the only way to work motion in with the gimbal. It works best if I first switch to airplane mode and then just turn on Bluetooth so nothing can interfere (incoming calls, texts, notifications) while the phone is taking the timelapse.
Have you tried taking a timelapse in the native iPhone camera app to see how it compares? I know you can't set exact timing there. But there are plenty of timelapse apps out there if that is your main need. The DJI Go app isn't required for that function unless the Tripod option switch needs to engaged in the app which I have not tried. However, if it is a bug in iOS 11 or something, they should fix it. Are you on iOS 11 now?
2017-10-5
DroneGuyEd
Other time lapse apps work fine (both handheld and via tripod ) and always produce results.  This is an issue with the combo of OSMO and DJI Go app.  Happens  with different i Phone models.  Just completely unreliable for me.
2017-10-7
smithsadams20
Banned
India
2017-10-11
MrRobert5823
Flight distance : 1385223 ft
smithsadams20 Posted at 2017-10-11 01:52
buy app reviews
Buy iOS Reviews
Not sure this is on topic....
2017-10-11
DroneGuyEd Posted at 2017-10-7 03:46
We are sorry for the late response because of Chinese National Holiday.
For Osmo Mobile, the shooting will be interrupted when you get a call in or low battery reminder.
Did you encounter this situation during shooting?
2017-10-12
DroneGuyEd
No, neither. This problem is more ingrained to the gear/app
2017-10-15
DroneGuyEd Posted at 2017-10-15 02:46
Then I suggest to send in the device for evaluation and test to locate the problem.
2017-10-15
DroneGuyEd
How do I do that and to where?
2017-10-18
DroneGuyEd Posted at 2017-10-18 05:09
If you locate in the United States, please fill in online repair here, the case will be created and as well as shipping label.
When you get it, please send the device in.
2017-10-18
DroneGuyEd
WIll try to set this up when I return next week.  Currently its just totally unreliable for any actions.
2017-10-19
