Firmware Failure!
1627 22 2017-10-14
VE5MDH
Flight distance : 8652 ft
I was forced to complete a new firmware to my P4 this morning.
it locked up at 99%. After 45 minutes, I figured this was a total failure.
I disconnected all and powered all items down.
I then started up all again.
My P4 is now disconnedted
No video signal to iPad 4 Mini w/Celular
No Data input from the drone
Completely usless!
Any ideas what I can do next???
I live in a tiny hamlet with an "Airport". There are no buildings at the airport, as the small hanger had a fire last year. The field is mainly used by the Air Force as a training "Touch & Go" field. It is also an Emergency Landing Strip for Comercial Aircraft, since it is a 10,000' paved strip.
Not too sure if the new Canadian Regs (9km near an Airport) is causing this failure?
Also, my drone is now flashing 2 LONG RED LED's, followed by 6 SHORT GREEN LED's. I am unable to locate a colour code of this ERROR Code means.Note: Hand Controller also flashes rapidly between RED/GREEN on the Left LED (Status Indicator).
Your assistance and knowledge is greatly appreciated!!! I was planning on scoring some beautiful video of the millions of waterfaul that pass over us this time of year for their fall migration run.
Lucky Lake, Saskatchewan is our QTH - CKQ5 is our airfield designator.
Michael David Hiltner
VE5MDH
2017-10-14
Vendex
Flight distance : 16722920 ft
Bulgaria
Did you use latest dji assistant 2 version?
2017-10-14
JW5255
Flight distance : 5291158 ft
Airport not an issue.  I would try the install again.  I have had failures on updates twice, but started over with DJI Assistant, and all went fine.
2017-10-14
VE5MDH
YouTube visual of this issue:
2017-10-14
Aardvark
Flight distance : 384432 ft
I think the aircraft is in an air safety zone, bottom of page 55 in manual indicates red flashing followed by normal status. If you've not upgraded the RC then you will need to do that as well to allow RC to talk to aircraft.
2017-10-14
fans5ef6e623
VE5MDH Posted at 2017-10-14 12:43
YouTube visual of this issue: https://www.youtube.com/watch?v=WOZJLQs5K4A
I’m having the exact same problem now
2017-10-14
Falcon123
Sweden
Have a brand new P4pro, tried to do first firmware update. Got stuck at 99% for almost 2 hrs then battery died. Not sure what to do next???
2017-10-14
ALABAMA
Flight distance : 10442687 ft
Falcon123 Posted at 2017-10-14 13:51
Recharge and do again.
2017-10-14
VE5MDH
JW5255 Posted at 2017-10-14 12:01
For some wierd reason, this is it! I just let things cool down for a couple hours, and re-connected DJI Go 4 (DJI Assistant) and it picked up that my RC needed to be reconfigured with a new firmware download.
Once completed, and rebooted the RC (which it did not want to properly co-operate to shut down), the whole system was back to normal!
Of course with the exception of the NO FLY ZONE ISSUE.
Thanks for sharing!
2017-10-14
VE5MDH
Vendex Posted at 2017-10-14 11:20
I have to use DJI Go 4. If I load the earlier version (DJI Assistant 2), it informs me to use DJI Go 4.
As per previous assistance, from there it worked it self out. Finally.
2017-10-14
VE5MDH
Aardvark Posted at 2017-10-14 12:49
Aardvark, once again you seem to hit the nail on the head! The issue was with the RC! Once it co-operated and received its proper update, then all was good! Of course once I was able to turn off my RC, which was a little uncooperative for a few minutes.
I have flown in our area (9km from the airdrome), but I think with this firmware update, I may not be allowed to launch my drone now. Real stupid rules for those who live by an inactive airdrome!
Oh well, at least I should be able to get out and capture the Fall Migration this year.
2017-10-14
VE5MDH
fans5ef6e623 Posted at 2017-10-14 13:10
Please read through all of the responses! It seems as though this firmware can be real finicky!
I loaded in order:
1) DJI Go 4
2) RC
3) Aircraft
Once the DJI Go 4 software read what was connected, it realised that something was wrong, and that the RC required a firmware update. (earlier in the day, the RC firmware was the first update I did!). Then the aircraft was done (where it hung up at 99%), and I just shut it down after 45 minutes, as I know if it is longer than 10 minutes, normally there is a problem it has encountered.
So, just charge everything once again and give it another go!
2017-10-14
VE5MDH
Exact issue that I encountered too!
Kindly review my responses to others for the answer. If you are still having bad luck, please share, and I'll try to assist further!
2017-10-14
Aardvark
VE5MDH Posted at 2017-10-14 14:38
Good to see you got it going, remember and check any spare batteries to see if they need updating. Power up with each spare and check aircraft 'update' status (DJI Go 4 or Assistant 2). The latest version of DJI Assistant 2 V1.1.6 should work OK.
2017-10-14
Vendex
Bulgaria
Update the remote controller firmware and relink it to the drone
2017-10-14
VE5MDH
Vendex Posted at 2017-10-14 16:17
I wasn't aware of a particular sequence in order to verify if the drone requires any updates.
I always turn on the app (DJI Go 4 or Litchi, then the RC is next followed by the Drone.
I need to observe this more carefully in the future.
Thanks for sharing.
2017-10-14
VE5MDH
Aardvark Posted at 2017-10-14 15:12
Yes, I shall also verify if my batteries need to be updated too! Easy one to overlook.
I do have 3, and have had only 2 in operation to date.
Good food for thought!
2017-10-14
fanscf5de830
Flight distance : 1023320 ft
Uninstalled DJI 4 from lpad turn off  iPad ,turn on  and reinstall the app DJI 4. Also clear your cache.It happens after the iOS update, in the past. Hope that will work for you.
2017-10-14
fanscf5de830
There’s been some complains about stuck on 99%, but just wait a few minutes after you reach 99% and see if it work. Check if everything looks good in the app and  do a fly with caution.I personally never had that problem ,but I had a  Ver 106 that is not working for me , waiting for a update.Good luck.
2017-10-14
DJI Susan
Glad to hear that you have figured it out. Enjoy it and happy flying!
2017-10-14
DJI Susan
Please refer the above and let us know whether it works or not. Feel free to contact us if you have more questions.
2017-10-14
PowerBand1
DJI Susan Posted at 2017-10-14 20:24
If the firmware upgrade is stuck on 99% on your phone or iPad disconnect it from the drone and plug it back into the remote and after a few minutes it should say update complete.
2017-10-15
DJI Susan
PowerBand1 Posted at 2017-10-15 01:57
Thanks for sharing your experience as well.
2017-10-17
