Crystalsky can't connect to Spark RC after switching to 2.4ghz
771 4 2017-10-15
TrevorL
Flight distance : 225978 ft
My Crystalsky can connect to the Spark RC with Wifi when set to 5.8ghz. When I change to 2.4ghz and the controller restarts the Crystalsky cannot see the Spark RC to connect to.
I'd like to be able to use 2.4ghz with my crystalsky
2017-10-15
DJI Susan
Please try to hold on the power button of RC for 9 seconds to reset the WiFi and check again.
2017-10-15
TrevorL
Ok I've done as follows;
Power on spark and RC. Connection verified
Power on CS and connect to RC
All ok ready to fly. Currently using 5.8ghz
Switch to 2.4mhz in Go4 app
RC restarts automatically
CS cannot see RC WiFi
Hold down RC button 9 seconds until 3beep-2beep
Still no RC WiFi found by CS
2017-10-15
TrevorL
Bump this post
2017-10-16
DJI Elektra
Please try to use an IOS device to search the wifi of RC when you switch to 5.8G channel.
Or you can try to link your drone without RC and see if the crystal sky can search the wifi of your drone.Also, restoring factory setting may solve the problem. If those solutions don't work, please inform us.
Thanks for your support.
2017-10-16
