Esteban Sanper
Mexico
jimenez Posted at 2019-1-7 22:32
hellow dji spark owners am sure alot of you are have cannot take off or your 4 ligths are solid red and some get a ESC status error when i first got this error a had crash my drone for the second time the first time the motor pin bend a little making it stuck when turning but i just replace the motor myself and work fine again the second time my drone crash the motor pin just got push down hiting the ESC Electronic speed controller wich controls the motor if 1 of the 4 ESC get damage you WILL get this problem with your drone
The fix is change the ESC ELECTRONIC SPEED CONTROLLER on the side that is damage more likely will be the motor that was hit or crash the picture you see is the part under the motor i change it and work just fine
hi friend
I have the same issue. I purchase a spark from second hand really cheap, the damage is crash. All on the spark works, can connect with the cell, connect with and RC, I can see the image, the spark was crashed and one of arm was broke. I replace the housing put all the components on the new housing in the device and appear works well. all looks like can fly without problems, but first appear the message: can´t take off, before of few attepms, the app show the warning: 2N Error ESC. I replace the ESC on these motor, and the warning dissappear, but have the same issue: Can´t take off. any idea about what can be bad?
