Shorter range with .0701?
1394 18 2017-11-1
DarylMax
Flight distance : 7537661 ft
I have not been able to fly to locations that I routinely had been before the update.  I've connected wifi auto, wifi trying both bands, and OTG,  same result.  I can't find any limitations set in the software.  In all directions shorter range, in some flights 50% less. Anyone else have this issue?
2017-11-1
DJI Elektra
What message did you get from your app? Please ensure that you do not wear Apple watch or other bluetooth devices.
When you fly your drone, you can choose the best channel from the  image transmission settings. Please fly your spark when most of the channels are green.
2017-11-1
Nelsonlee
Flight distance : 2779203 ft
Malaysia
Yes, I also have this range issues, my previous firmware version work fine with good range but this latest firmware is useless.I will roll back to the previous firmware.
2017-11-1
fans61699a75
Flight distance : 24897940 ft
Its your otg cable. It limits the distance. Fly with wifi. Otg doesnt make sense anymore
2017-11-1
Nelsonlee
Malaysia
fans61699a75 Posted at 2017-11-1 21:33
tested all with 2.4G, 5G, OTG.....all the same short range!!!
2017-11-1
Matioupi
Flight distance : 922569 ft
I make an opposite observation... I got longer ranges with .0701 than I had with .0600
2017-11-1
DJI Elektra
Nelsonlee Posted at 2017-11-1 19:55
Did you check the information mentioned in 2#?  What message you got from your app? Please tell me the model of  your phone.
2017-11-1
DarylMax
DJI Elektra Posted at 2017-11-1 19:41
The messages are the same as when you lose the signal and return to home.  It's as if I've lost my transmitter antennas.  I do have a Fitbit but learned long ago to remove it, turn off Bluetooth, and make sure anyone with me has it off too.
2017-11-2
medyq69
Flight distance : 15358 ft
Poland
DarylMax Posted at 2017-11-2 04:00
every next update makes range shorten - finaly spark will become selfie dron with range of 5 m . I did test in park near home befiore update - with low signal , using smartphone not controler i achived 98m in straight line. I need to test it today/tomorow after i updated it in same location. If i get same issue with range i will try downgrade to prev version cus 360 pano i think also doesnt work like expected
2017-11-2
DarylMax
I'll add that I have an iPhone 7 Plus.  Going to do another test flight in about an hour, then downgrade the firmware are repeat the same path and see if there is a difference.
2017-11-2
S-e-ven
Flight distance : 5922034 ft
Thailand
I could not fly, today.
Cloudy, 80-100%, very now and then raining
But I had that in mind, to check on the yesterday flown distances.
What I think, I saw, scanning this topic:
FCC Pilots complaining about less range, CE Pilots are getting more.
How about, we focusing on to negate or affirm this first sight?
As soon, as I have the opportunity, I will check on this in FCC area and report back
2017-11-2
DarylMax
S-e-ven Posted at 2017-11-2 04:44
FCC, San Antonio here. Cloudy, then sunny this pm
2017-11-2
Nelsonlee
Malaysia
DJI Elektra Posted at 2017-11-1 22:57
Your DJI Go only prompt SIGNAL LOST! RETURN HOME!
2017-11-2
S-e-ven
Thailand
Got the idea for a poll:
Range with .701
https://forum.dji.com/thread-118207-1-1.html
2017-11-2
DJI Elektra
DarylMax Posted at 2017-11-2 04:25
Please keep us updated about the range. Thanks for you attention.
2017-11-2
DarylMax
DJI Elektra Posted at 2017-11-2 23:44
By manual channel selection, I have gained a little more range in .701.  Still not what I was reaching in .600 with the remote controller.   The weather has not been ideal so I'm hoping to try it all again this afternoon when the low clouds burn off.  Thanks Elektra
2017-11-3
S-e-ven
Thailand
I flew with .701, go 4 - 4.1.10, otg, and reached the before with .600 flown distances.
Are you flying with the "latest version" Go 4?
2017-11-3
DarylMax
iOS 4.1.15.  I’ll let you know how I he next tests go.  Need the drizzle to burn off.
2017-11-3
Eduardo0
Flight distance : 6443990 ft
Brazil
Matioupi Posted at 2017-11-1 22:39
Same with me.
2017-11-3
