Nigel_
Flight distance : 388642 ft
It should be close to zero unless you apply enough force to compress the springs.
If the springs are not keeping the props firmly locked in place then you can replace the plastic hub mounts + springs. Better to do it sooner rather than after a prop flies off mid-air!
It is not common to have problems with P4 propellers though, they can last for years.
If the propellers have impacted something hard like a rock then consider replacing the mounts as well as the props, hitting soft grass doesn't require replacement unless there is visible damage. |
