How to use GS pro with N3 autopilot?
2006 9 2017-11-9
fans976aa675
Finland
Good morning!
I want to replace pixhawk with N3. My question is how to use planning software like GS pro with N3? Do I need datalink 3 for that? Problem with the datalink 3 is that it's not available in my country. Main flying purpose will be mapping/photogrammetry missions.
What about N3 + lightbridge 2. Does that combination support GS pro? I have read that UgCS should work with N3+LB2.
2017-11-9
DJI Thor
Flight distance : 13602 ft
Either N3 + Lightbridge 2 or N3+ Datalink 3. If you mainly use it for agriculture, then Datalink 3 is recommended, but for normal flight, you can use N3 + Lightbridge 2.
2017-11-12
Nakadrone
Brazil
DJI Thor Posted at 2017-11-12 18:37
I´ll use for agriculture survey... How can i shutter my camera on N3???
2018-9-28
DJI Thor
Nakadrone Posted at 2018-9-28 09:29
Hi Naka, if you use N3+LB2, you can connect the camera shutter signal to a channel between F3-F8, then set this channel as the shutter in DJI Assistant 2, set up the trigger pulse width, then you'll be able to use the shutter function on Lightbridge 2. Please note that Datalink 3 can't be used for shooting, thanks.
2018-9-29
Sword
Flight distance : 1476 ft
DJI Thor Posted at 2018-9-29 05:21
But if using  GS Pro, the way cannot work. A third-party camera cannot shutter automatically per your recommendation if  I don't use Ronin-MX.
2018-9-30
Nakadrone
Brazil
I’m trying to understand the reason why DJI blocks the shutter on camera by GS Pro...
A Ronin Gimbal is very very heavy and that’s a payload that we don’t want in the drone because it’s not functional in agriculture and because it’ll loose autonomy.
Another interesting point is the video transmission from Lightbridge 2... We don’t need it... a Datalink 3 with N3 is enough to plan missions in GS Pro and mapping with all that we need (of course we’ll need to extract the log from N3 to geotag images).
DJI could sell much more N3 and Datalink 3 opening these functions...
2018-9-30
DJI Thor
Sword Posted at 2018-9-30 00:25
Hi Sword, it is true that to use the auto shutter in the GS pro, users may need to use the DJI camera and the third-party camera that Ronin-MX supported. Thank you for your attention.
2018-10-5
DJI Thor
Nakadrone Posted at 2018-9-30 09:44
Hi Nakadrone, it is because Datalink 3 is the agricultural flight controller, there is no module that can realize it. Thanks for your understanding.
2018-10-5
Nakadrone
Brazil
DJI Thor Posted at 2018-10-5 03:50
Hi Thor... there's a way to activate Landing Gear in N3 using Datalink 3?
I just need to activate a Landing gear... Just it...
2019-2-7
DJI Thor
Nakadrone Posted at 2-7 11:01
Hi there, sorry for the late reply. For Datalink 3, it is unable to trigger the landing gear, you may need LB2 to map the F channel to the landing gear. Please let me know if you are using the third-party landing gear. Thanks.
2019-2-15
