DJI S900 linked to A2 controller but no actuation
822 5 2017-11-13
ariel.baron
Hello,
I have a DJI S900 with an A2 controller. From the A2 assistant software you can see that the futaba 14SGH controller is linked to the A2 controller. There is also a green LED light on the drone. However when I take the drone off of the A2 assistant there is no actuation in the propellers. The drone passes the propeller test
2017-11-13
DennisMurry08
Flight distance : 5948264 ft
I had the green blinking led and it turned out to be bad...replaced it and everything worked...don’t know if that’s your issue but thought I’d let you know
2017-11-14
ariel.baron
DennisMurry08 Posted at 2017-11-14 09:56
what was bad? the hardware or was it a software issue?
2017-11-14
ariel.baron
Hi, It turned out that the magnetometer calibration needed to be done or else it wouldn't fly
2017-11-15
DennisMurry08
ariel.baron Posted at 2017-11-15 08:37
The old GPS dance...good, doesn’t cost anything...
2017-11-15
DJI Susan
Both of the Remote control sticks should be toggled to the lower left corner during Channel Calibration. The slider of ATRU four channels should be toggled on the left side. If there's any different, please click Channel Reverse.
2017-11-19
