Rodger8
Flight distance : 20145135 ft
ehcropydoc Posted at 2017-11-15 09:12
This has nothing to do with Pre-Flights or speediness of deployment. Instead, it has everything to do with wear and tear. We have found in our operations, the less we have to remove equipment, the less chance of a failure. Also, after removing props a few thousand times, there will be some wear and tear where if we are able to keep props installed, we will have to worry much less about mid-flight failures.
Just curious, why couldn't you take your measurements from your Inspire? |
