Lighbridge Camera Mode Switch problem
1237 2 2015-4-11
richardhuison
Flight distance : 54455 ft
on mapping a 3 position switch on my Futaba 14SG for the camera Mode. The LB software shows the switch moving between "H free" "Reset" "H Trace" but the gimbal does act in the correct manor. It will reset but only in the "H Trace" position.
I've followed this post but can't figure out the issue
2015-4-11
Tahoe_Ed
Flight distance : 2605 ft
My question is what is it not doing?  Have you power cycle the ground unit?  Did you check the Zen Assistant?
2015-4-11
richardhuison
I did power cycle the LB on the Ground Unit and i checked the Gimbal set up and everything is behaving as it should in the software. but this does not translate to the gimabl.
I took some videos to show the problem
http://youtu.be/rptfvb31CSg
http://youtu.be/JVEa-XwhndA
http://youtu.be/NHP2Eh-nUbA
2015-4-12
