litchi app
699 6 2017-11-30
silicon falcon
Does anyone know, if you change the altitudes of various waypoints on the litchi app, does the p3 climb gradually to the next waypoint or go to  the next waypoint and climb to  the desired altitude?
2017-11-30
Mark The Droner
Flight distance : 2917 ft
It does a combination of both but doesn't fly in a straight line like that to the waypoint.  It will likely find the altitude first and then continue horizontally to the waypoint.
2017-11-30
PeteHB
Mark The Droner Posted at 2017-11-30 13:27
If you use interpolate does it gradually change altitude between the two? I don't know as I am just looking at using Litchi and it seems to offer some very good solutions so I think I will invest just to experiment.
2017-11-30
Mark The Droner
When I say it does a combination of both, I mean it moves in the direction it's supposed to go, and it changes elevation, and it does both of these at the same time.  But it will reach elevation first.
2017-11-30
Dockater
Flight distance : 139649 ft
Mark is right, it will adjust altitude and horizontal position at the same time, but it has also been given a speed to follow. My observations lead me to believe the ac uses its speed setting primarily for the horizontal positioning, in cases where I wanted a vertical climb I have placed two waypoints at more or less the same position with different altitude settings. My subjective feeling is that the ac moved quickly to its new waypoint with minimal altitude change and completed the rest of the leg as a vertical climb. It would be interesting to know the protocols and the algorithm the software uses.
2017-11-30
Labroides
Flight distance : 9991457 ft
When I set different altitudes for waypoints, Litchi flies smoothly descending or ascending as it goes.
It does not fly to the next waypoint and then climb to altitude.
2017-11-30
silicon falcon
Thanks for the input. We will be flying the path of a bullet that ricochet off a pond. We know the bullets elevation at various points and was curious as tohow the elevation changes would be made.
2017-12-1
