Beware of Scam FAA Websites
1647 9 2017-12-4
DNR 1
Flight distance : 1689478 ft
If you are looking to register your drone, be sure to go to the right website, which is here:
FAA
The other day I almost fell victim to a scam site that was charging up to $199 for registrations.
It didn't make any sense why so much, but if a scam, which it was, makes total sense now.
The thing is the website looked legit and mirrored the FAA's.
2017-12-4
Epicdoom
Flight distance : 340620 ft
did you report the site ? if not please link it to me I'll do it so no one falls for it
2017-12-4
M.C. Pilot
Flight distance : 10400463 ft
Those scammers do anything to make quick bucks.
2017-12-4
SunSets
Flight distance : 311089 ft
Thanks for the heads-up...  I sent 5$ for the P3S...  Just got a spark now... I'll try reg. after 1.1.18 or when the temp. is above 40. Hard winters here, Today in the 50's.... all downhill now. Tomorrow lake effect snow, temps 30 to 20 f. this trend last till March... Cheers
2017-12-4
Labroides
Flight distance : 26781877 ft
These days the FAA is almost with the scammers.
Their website still tells you that you have to register your drone although that was struck down back in May 2017.
There is currently no requirement to register with the FAA for recreational flying
https://www.cadc.uscourts.gov/in ... 15-1495-1675918.pdf
https://www.recode.net/2017/5/19 ... istration-rules-faa
2017-12-4
microlinux
Flight distance : 2576972 ft
Labroides Posted at 2017-12-4 19:16
They pretty clearly state the exception and provide a link to the recreational info page.
2017-12-4
Labroides
microlinux Posted at 2017-12-4 21:43
They have nothing about it here on their main registration page: https://registermyuas.faa.gov/
One would have thought they would have closed the web page down but it's still running and taking money from suckers that don't know their registration is no longer required.
I have seen a small mention of it on another of their webpages but can't find that one now.
2017-12-4
microlinux
Labroides Posted at 2017-12-4 22:01
You need to register your aircraft if it weighs between 0.55 lbs. (250 grams) and up to 55 lbs. (25 kg) and you are not flying under the Special Rule for Model Aircraft.
And there's a link that leads to this:
You don't need permission from the FAA to fly your UAS under the Special Rule for Model Aircraft, but you must always fly safely. You may elect to register your UAS to help in the recovery of lost equipment.
2017-12-4
DJI Susan
Hello Sir, thanks for your kind reminder. Hope more people will realize this and do not be scammed.
2017-12-5
repairman
Flight distance : 16581 ft
thanks for the heads up.
2017-12-5
