TOZO after market signal *Reflectors?
1268 14 2017-12-8
sednalb
Flight distance : 30653 ft
Sorry about my previous post, i mislead in the by saying amplifiers; What i meant to say was the TOZO Signal Relfectors,  And yes they fit on the p4p and p4p+ controllers,  Thing is the signal reflectors that mount onto the anntena have to be in a fixed forward position.  I can fold it up towards me wondering if i loosed the 2 atenna and moving them 180 degrees opposite, i can then fold it down to relflect out?  I am in no way of supporting this addon or have any stake in it, was given to me as a present and just wondering feedback from everyone.  I feel Like they may inhibit in certain angles if i can not angle it down?
TOZO Reflectors in the "flat position"
Folded Towards me.
Folded Towards me.
2017-12-8
Geebax
They needs to be installed 180 degrees from what you have now. Then the antennas must be vertical, so the reflectors point away from you. But in any event, looking at the reflections in the brass,, which look quite distorted, they probably won't do any good anyway.
2017-12-8
Hellsgate
Flight distance : 1991555 ft
Are you sure you didnt put them on upside down as well as backwards i found with mine there is a correct way up otherwise they dont fit correctly and will distort the reflectors. The slot the antenna go into on the reflectors is slightly larger on one end
2017-12-9
Hellsgate
And  geebax is correct both your antenna need to point straight up with the reflector pointing away from you. If you do use these then you will need to be facing the drone at all times otherwise you will loose signal easily. They are very directional
2017-12-9
Hellsgate
This is how it should look
2017-12-9
Hellsgate
Front view
2017-12-9
Hellsgate
Ooops try that
2017-12-9
Hellsgate
Notice you can see the reflection of the antennas the less distortion in that reflection will give you a much better quality signal
2017-12-9
sednalb
Hellsgate Posted at 2017-12-9 00:46
Thanks for that mate, i went full idiot in my brain after a long week of work i just flipped it around
2017-12-9
sednalb
the reason i had them on that way is i like to rather aim my remote down then up when flying, old habit from RC flying
2017-12-9
Mark The Droner
Flight distance : 2917 ft
Yes - I've seen photos with the deflectors on backwards and upside down.  I just checked and yeah, they're on this product and other products too.  The idea is you're supposed to bend the antenna down instead of up and then fly with the antennas upside down.  Seems weird to me though.  Also, my P3P controller antenna won't twist upside down.  So the whole thing seems silly.
Another thing that's interesting is the seller is using Erskine's original windsurfer copyright design from fifteen years ago to promote their product.
2017-12-9
sednalb
Mark The Droner Posted at 2017-12-9 03:33
[view_image]
It snowed here, and i was busy with my business, going to try it out tomorrow.
2017-12-9
lannes
Flight distance : 4465 ft
Geebax Posted at 2017-12-8 23:00
What happens if your trying for an altitude record and the AC is directly above you ?
Installed facing upwards would work in this case
2017-12-9
Geebax
lannes Posted at 2017-12-9 22:40
Not at all, the worst position for good reception is to fly the aicraft directly above you, because the antennas in the legs of the aircraft point downwards. You can add all manner of antenna modifications to the RC unit, but usually no-one modifies the aircraft, and that is the weakest point.
2017-12-10
Mark The Droner
Haha reminds me of this old vid from 2014
But Geebax is right of course, the controller is in a dead area of the Phantom's receiving antenna when you go straight up unless you do a mod to the AC
You can see he almost lost it at around the 8:30 mark going forward ... and at 8:51 you get a glimpse of the legs and it looks like he might have done an AC antenna mod... can't tell for sure but that's what it looks like
2017-12-10
