Kloo Gee
Flight distance : 16783757 ft
Looking at the logs and the video, from my uneducated opinion, the behavior seems consistent with the Spark struggling against a very strong wind. In the logs, we can see that the aircraft is pitched at a fairly steep angle 30-37 degrees and yet it is not moving at all (0 mph). You can see this on lines 3308-3314 of the log file while the aircraft is in GoHome mode. To me this indicates it was trying to buck a wind that was at least 22mph. Similar type of behavior can be seen all along the log file showing that the aircraft is pitched at a steep angle, but not moving hardly at all. Normally, I would expect if the aircraft were pitched at such a steep angle for long periods of time, it would be moving at a very fast rate if there were no winds.
Also, looking at the location of your flight, it looks like you may have been flying across a little bit of a valley. If that is the case, then it is very possible for the negative altitude numbers. The starting location of your flight is the base level (i.e. 0 meters). If the landing spot was lower than the takeoff location, then the negative numbers are what would be expected.
Weather for the general area shows that the max wind speed for the day was 16mph. https://www.wunderground.com/his ... name=South%20Africa
Localized wind speeds could be even faster than recorded for the area based on geographic features.
The above are based solely on this uneducated, non-expert interpreted from the provided log files. If you see something different in the logs I'm misinterpreting or haven't taken into account, I would be interested to see so I can learn more. Also, I obviously wasn't there, so hard for me to compare my observations to real life.
