[Solved] POST new firmware.. Now I1 will not transform to travel mode?!
123Next >
7739 91 2015-4-15
gybo102
Flight distance : 2426230 ft
Install of the firmware was normal, no issues. Did not get to fly yet, but went to put it all away and when trying to put it into travel mode the way I always have ( power up RC, then I1, wait about 5 seconds then toggle the transform rocker 4 times) the light will go blue like it is supposed to... but does nothing. And the really odd thing is I can just rock the transform switch up once, and it will put the landing gear up.... while doing nothing. No motors turning or anything. it will go all the way up.
Am I missing something? Ill work on a video if anyone needs to see what I am describing.
Thank you
2015-4-15
tgif9623
Have you done a new compass calibration? That may be the problem
2015-4-15
gybo102
tgif9623@comcas Posted at 2015-4-16 10:08
I have. I never have been able to put the landing gear up while its just sitting there before. so that's odd to me as well.
2015-4-15
gybo102
Here ya go.. sorry.. low quality vid
2015-4-15
tgif9623
Im assuming the gimbal/camera is detatched?
2015-4-15
gybo102
nope... it is not
2015-4-15
tgif9623
just watched video.....never seen that before
2015-4-15
dbeck
Had the same problem!!!  NO CARPET.. Put a piece of paper underneath the sensors OR put it on a plain slick surface and try again
2015-4-15
gybo102
I know not to do it on the carpet. I always do it in the bathroom. but... the bathroom is a mess. So I did it there only for the purpose of the video. At least before it would try on the carpet, now it does nothing.
2015-4-15
dbeck
Put a some newsprint underneath the sensors...guarantee it will fix it the issue!
2015-4-15
FoxSTI
Flight distance : 11286 ft
The inspire will not transform on: Grass, carpet or anything that is not smooth or reflects sound.
Try it on a table I am very sure this had nothing to do with the new firmware.
2015-4-15
gybo102
It does the same thing on my bathroom tile floor. I should have mentioned this is not the first time I am trying to put it into travel mode. I learned not to do it on carpet the first day... in the first hr of messing with it. It was on the carpet only for the purpose of the video, does the same thing on tile, the place I always have done travel mode. It worked fine right before the firmware, now it wont transform properly. Im a little nervous to fly it now. also... as I mentioned, I should not be able to put the arms up while sitting on the ground like it does.
2015-4-15
gybo102
On hard floor... so, there is an issue.
2015-4-15
dbeck
Try reinstalling the FM and the App...weird
2015-4-15
gybo102
How can I force it to install the firmware again? I tried to, and it goes straight to never ending beep.
2015-4-15
gybo102
the app should not matter, I do not even have the iPhone connected. Its RC to I1. But I even tried to enter travel mode from the app, does the same thing.
2015-4-15
gybo102
Any other ideas? trying to reload the firmware.. but... it wont take.
2015-4-15
gybo102
========== 2014.01.01 00:00:11 unsynchronized ======
Packet: WM610_FW_V01.02.01.00.bin
Result: Failed.
Reboot the aircraft and try to upgrade the firmware again.
Getting frustrated... It will not accept the update at all. tried many times. Any thoughts?
2015-4-15
PaperPlane
It's been a while but I had this happen to me with the original firmware. I had just finished a session and had brought everything inside to pack up (it was cold outside). It wouldn't go into travel mode after many attempts. I had it on a coffee table. I ended up powering everything down, pulling the battery out of the inspire, closing the pilot app and rebooting my ipad. Had a cup of coffee, powered everything up and it worked as normal. Don't know if one or a combo of those things did it.
2015-4-15
gybo102
At this point, I have cycled batts about 6-7 times. tired with RC / iPhone 10+ times and now tried to install the firmware on the bird 5 times with no success since the first firmware install. Im getting super frustrated, never had an issue with my I1 till now. And now.... I will have a hard time sleeping knowing there is a problem. :@
2015-4-15
method007
Flight distance : 110449 ft
Have you tried using the option in your software?  Rather than the remote?
2015-4-15
DJI-Autumn
Could you pls show me the upgrade log file? I need to make sure whether the upgrade is successful or not. Ths.
2015-4-15
gybo102
DJI-Autumn Posted at 2015-4-16 11:22
Could you pls show me the upgrade log file? I need to make sure whether the upgrade is successful or ...
This is what I get now
Result: Failed.
2015-4-15
DJI-Autumn
gybo102 Posted at 2015-4-16 11:25
Could you pls show me the log file?Try re-upgrade.
2015-4-15
gybo102
That's it. I review\ delete after every try, get the same message every time. Is there more that should be there?
2015-4-15
gybo102
other then putting the sd card in the camera and powering the I1, how do re-upgrade. When I do that, it sits for about 5 seconds then just give a never ending sold beep.
2015-4-15
mattd
Please post log file located in hidden directory, x:\misc\logname
x being the sd card
2015-4-15
gybo102
Looks normal here.
2015-4-15
mattd
contact live support on the Inspire 1 DJI website.
2015-4-15
DJI-Autumn
gybo102 Posted at 2015-4-16 11:38
other then putting the sd card in the camera and powering the I1, how do re-upgrade. When I do that, ...
Set hidden folder visible, read the file "MISC\LOG\WM610_FW_LOG_AB.txt".
2015-4-15
gybo102
ok.. one moment...
2015-4-15
gybo102
[00062340]Packet [C:\WM610_FW_V01.02.01.00.bin] detected.
[00062353]Packet upgrade start...
[00062364]Packet checking...
[00062378]Done.
[00062383]Version checking[1]...
[00062388][01 00] v1.3.1993 -> v1.7.2499 need upgrade
[00062447][03 05] v34.1.0.5 -> v34.1.0.5
[00062487][03 06] v1.15.4.9 -> v2.0.5.10 need upgrade.
[00062498][04 00] v1.5.0.61 -> v1.16.0.76 need upgrade.
[00062528][05 00] v2.4.6.1 -> v2.5.6.1 need upgrade.
[00062536][08 00] v1.10.0.14 -> v1.11.0.19 need upgrade.
[00062551][09 00] v1.6.6.1 -> v1.7.0.3 need upgrade.
[00062587][11 00] v3.3.0.0 -> v3.2.1.0
[00062627][12 00] v1.3.0.60 -> v1.3.0.60
[00062668][12 01] v1.3.0.60 -> v1.3.0.60
[00062727][12 02] v1.3.0.60 -> v1.3.0.60
[00062767][12 03] v1.3.0.60 -> v1.3.0.60
[00062836][15 00] v1.1.1.0 -> v1.1.2.0 need upgrade.
[00062867][17 00] v1.0.2.4 -> v1.1.0.1 need upgrade.
[00062951][17 01] v1.0.0.9 -> v2.0.0.1 need upgrade.
[00062967][19 00] v1.0.8.59 -> v1.0.8.59
[00062978]Done.
[00062984]Waiting for user confirm...
[00063271]User confirmed.
[00063280]Firmware upgrading[1]...
[00065827][01 00] Firmware upgrading start...
  [00010133][01 00] Firmware upgrade finished successfully.
[00010139]Done.
[00010148]Version checking[2]...
[00010157][01 00] v1.7.2499 -> v1.7.2499
[00010162][01 01] v0.0.0 -> v1.7.2499 need upgrade
[00010213][03 05] v34.1.0.5 -> v34.1.0.5
[00010255][03 06] v1.15.4.9 -> v2.0.5.10 need upgrade.
[00010269][04 00] v1.5.0.61 -> v1.16.0.76 need upgrade.
[00010314][05 00] v2.4.6.1 -> v2.5.6.1 need upgrade.
[00010334][08 00] v1.10.0.14 -> v1.11.0.19 need upgrade.
[00010348][09 00] v1.6.6.1 -> v1.7.0.3 need upgrade.
[00010395][11 00] v3.3.0.0 -> v3.2.1.0
[00010434][12 00] v1.3.0.60 -> v1.3.0.60
[00010474][12 01] v1.3.0.60 -> v1.3.0.60
[00010514][12 02] v1.3.0.60 -> v1.3.0.60
[00010574][12 03] v1.3.0.60 -> v1.3.0.60
[00010639][15 00] v1.1.1.0 -> v1.1.2.0 need upgrade.
[00010675][17 00] v1.0.2.4 -> v1.1.0.1 need upgrade.
[00010734][17 01] v1.0.0.9 -> v2.0.0.1 need upgrade.
[00010749][19 00] v1.0.8.59 -> v1.0.8.59
[00010767]Done.
[00010771]Firmware upgrading[2]...
[00010890][01 01] Firmware upgrading start...
[00021135][01 01] Firmware upgrade finished successfully.
[00021333][03 06] Firmware upgrading start...
[00209931][03 06] Firmware upgrade finished successfully.
[00209965][17 00] Firmware upgrading start...
[00245788][17 00] Firmware upgrade finished successfully.
[00245808][17 01] Firmware upgrading start...
[00010176]========== 2015.04.15 13:52:25 =====================
[00010186]Packet [C:\WM610_FW_V01.02.01.00.bin] detected.
[00010195]Packet upgrade start...
[00010211]Packet checking...
[00010222]Done.
[00010225]Version checking[1]...
[00010232][01 00] v1.7.2499 -> v1.7.2499
[00010237][01 01] v1.7.2499 -> v1.7.2499
[00010281][03 05] v34.1.0.5 -> v34.1.0.5
[00010320][03 06] v2.0.5.10 -> v2.0.5.10
[00010335][04 00] v1.5.0.61 -> v1.16.0.76 need upgrade.
[00010369][05 00] v2.4.6.1 -> v2.5.6.1 need upgrade.
[00010382][08 00] v1.10.0.14 -> v1.11.0.19 need upgrade.
[00010397][09 00] v1.6.6.1 -> v1.7.0.3 need upgrade.
[00010421][11 00] v3.3.0.0 -> v3.2.1.0
[00010481][12 00] v1.3.0.60 -> v1.3.0.60
[00010541][12 01] v1.3.0.60 -> v1.3.0.60
[00010602][12 02] v1.3.0.60 -> v1.3.0.60
[00010661][12 03] v1.3.0.60 -> v1.3.0.60
[00010723][15 00] v1.1.1.0 -> v1.1.2.0 need upgrade.
[00013261][17 00] v1.1.0.1 -> v1.1.0.1
[00025765][17 01] device not detected.
[00025784][19 00] v1.0.8.59 -> v1.0.8.59
[00025788]Done.
[00027794]Waiting for user confirm...
[00028287]User confirmed.
[00028299]Firmware upgrading[1]...
[00028330][05 00] Firmware upgrading start...
[00052634][05 00] Firmware upgrade finished successfully.
[00052650][15 00] Firmware upgrading start...
[00070732][15 00] Firmware upgrade finished successfully.
[00070765][09 00] Firmware upgrading start...
[00102665][09 00] Firmware upgrade finished successfully.
[00103479][08 00] Firmware upgrading start...
[00418112][08 00] Firmware upgrade finished successfully.
[00418148][04 00] Firmware upgrading start...
[00450271][04 00] Firmware upgrade finished successfully.
[00450281]Done.
[00450287]Version checking[2]...
[00450291][01 00] v1.7.2499 -> v1.7.2499
[00450297][01 01] v1.7.2499 -> v1.7.2499
[00450329][03 05] v34.1.0.5 -> v34.1.0.5
[00450368][03 06] v2.0.5.10 -> v2.0.5.10
[00450378][04 00] v1.16.0.76 -> v1.16.0.76
[00450413][05 00] v2.5.6.1 -> v2.5.6.1
[00450423][08 00] v1.11.0.19 -> v1.11.0.19
[00450439][09 00] v1.7.0.3 -> v1.7.0.3
[00450468][11 00] v3.3.0.0 -> v3.2.1.0
[00450509][12 00] v1.3.0.60 -> v1.3.0.60
[00450568][12 01] v1.3.0.60 -> v1.3.0.60
[00450629][12 02] v1.3.0.60 -> v1.3.0.60
[00450688][12 03] v1.3.0.60 -> v1.3.0.60
[00450776][15 00] v1.1.2.0 -> v1.1.2.0
[00450810][17 00] v1.1.0.1 -> v1.1.0.1
[00463322][17 01] device not detected.
[00463348][19 00] v1.0.8.59 -> v1.0.8.59
[00463355]Packet upgrade failed at version checking.
[00010268]========== 2014.01.01 00:00:09 unsynchronized ======
[00010277]Packet [C:\WM610_FW_V01.02.01.00.bin] detected.
[00010280]Packet upgrade start...
[00010293]Packet checking...
[00010300]Done.
[00010305]Version checking[1]...
[00010310][01 00] v1.7.2499 -> v1.7.2499
[00010315][01 01] v1.7.2499 -> v1.7.2499
[00010350][03 05] v34.1.0.5 -> v34.1.0.5
[00010397][03 06] v2.0.5.10 -> v2.0.5.10
[00010409][04 00] v1.16.0.76 -> v1.16.0.76
[00010430][05 00] v2.5.6.1 -> v2.5.6.1
[00010449][08 00] v1.11.0.19 -> v1.11.0.19
[00010466][09 00] v1.7.0.3 -> v1.7.0.3
[00010493][11 00] v3.3.0.0 -> v3.2.1.0
[00010531][12 00] v1.3.0.60 -> v1.3.0.60
[00010571][12 01] v1.3.0.60 -> v1.3.0.60
[00010631][12 02] v1.3.0.60 -> v1.3.0.60
[00010671][12 03] v1.3.0.60 -> v1.3.0.60
[00010732][15 00] v1.1.2.0 -> v1.1.2.0
[00010771][17 00] v1.1.0.1 -> v1.1.0.1
[00023275][17 01] device not detected.
[00023294][19 00] v1.0.8.59 -> v1.0.8.59
[00023298]Packet upgrade failed at version checking.
[00010164]========== 2014.01.01 00:00:10 unsynchronized ======
[00010174]Packet [C:\WM610_FW_V01.02.01.00.bin] detected.
[00010183]Packet upgrade start...
[00010198]Packet checking...
[00010209]Done.
[00010216]Version checking[1]...
[00010223][01 00] v1.7.2499 -> v1.7.2499
[00010229][01 01] v1.7.2499 -> v1.7.2499
[00010263][03 05] v34.1.0.5 -> v34.1.0.5
[00010283][03 06] v2.0.5.10 -> v2.0.5.10
[00010298][04 00] v1.16.0.76 -> v1.16.0.76
[00010326][05 00] v2.5.6.1 -> v2.5.6.1
[00010336][08 00] v1.11.0.19 -> v1.11.0.19
[00010348][09 00] v1.7.0.3 -> v1.7.0.3
[00010384][11 00] v3.3.0.0 -> v3.2.1.0
[00010426][12 00] v1.3.0.60 -> v1.3.0.60
[00010484][12 01] v1.3.0.60 -> v1.3.0.60
[00010524][12 02] v1.3.0.60 -> v1.3.0.60
[00010584][12 03] v1.3.0.60 -> v1.3.0.60
[00010642][15 00] v1.1.2.0 -> v1.1.2.0
[00010663][17 00] v1.1.0.1 -> v1.1.0.1
[00023167][17 01] device not detected.
[00023192][19 00] v1.0.8.59 -> v1.0.8.59
[00023195]Packet upgrade failed at version checking.
[00010279]========== 2014.01.01 00:00:10 unsynchronized ======
[00010292]Packet [C:\WM610_FW_V01.02.01.00.bin] detected.
[00010302]Packet upgrade start...
[00010317]Packet checking...
[00010327]Done.
[00010332]Version checking[1]...
[00010337][01 00] v1.7.2499 -> v1.7.2499
[00010342][01 01] v1.7.2499 -> v1.7.2499
[00010388][03 05] v34.1.0.5 -> v34.1.0.5
[00010421][03 06] v2.0.5.10 -> v2.0.5.10
[00010443][04 00] v1.16.0.76 -> v1.16.0.76
[00010481][05 00] v2.5.6.1 -> v2.5.6.1
[00010488][08 00] v1.11.0.19 -> v1.11.0.19
[00010506][09 00] v1.7.0.3 -> v1.7.0.3
[00010560][11 00] v3.0.0.11 -> v3.2.1.0 need upgrade.
[00010621][12 00] v1.3.0.60 -> v1.3.0.60
[00010680][12 01] v1.3.0.60 -> v1.3.0.60
[00010741][12 02] v1.3.0.60 -> v1.3.0.60
[00010801][12 03] v1.3.0.60 -> v1.3.0.60
[00010861][15 00] v1.1.2.0 -> v1.1.2.0
[00010881][17 00] v1.1.0.1 -> v1.1.0.1
[00023392][17 01] device not detected.
[00023415][19 00] v1.0.8.59 -> v1.0.8.59
[00023420]Done.
[00025428]Waiting for user confirm...
[00035438]Timeout, start upgrade automatically.
[00035450]Firmware upgrading[1]...
[00035476][11 00] Firmware upgrading start...
[00095310][11 00] Firmware upgrade finished successfully.
[00095320]Done.
[00095325]Version checking[2]...
[00095338][01 00] v1.7.2499 -> v1.7.2499
[00095342][01 01] v1.7.2499 -> v1.7.2499
[00095379][03 05] v34.1.0.5 -> v34.1.0.5
[00095413][03 06] v2.0.5.10 -> v2.0.5.10
[00095423][04 00] v1.16.0.76 -> v1.16.0.76
[00095473][05 00] v2.5.6.1 -> v2.5.6.1
[00095483][08 00] v1.11.0.19 -> v1.11.0.19
[00095498][09 00] v1.7.0.3 -> v1.7.0.3
[00095552][11 00] v3.2.1.0 -> v3.2.1.0
[00095612][12 00] v1.3.0.60 -> v1.3.0.60
[00095673][12 01] v1.3.0.60 -> v1.3.0.60
[00095736][12 02] v1.3.0.60 -> v1.3.0.60
[00095792][12 03] v1.3.0.60 -> v1.3.0.60
[00095865][15 00] v1.1.2.0 -> v1.1.2.0
[00095892][17 00] v1.1.0.1 -> v1.1.0.1
[00108400][17 01] device not detected.
[00108421][19 00] v1.0.8.59 -> v1.0.8.59
[00108425]Packet upgrade failed at version checking.
[00010279]========== 2014.01.01 00:00:11 unsynchronized ======
[00010289]Packet [C:\WM610_FW_V01.02.01.00.bin] detected.
[00010299]Packet upgrade start...
[00010313]Packet checking...
[00010322]Done.
[00010329]Version checking[1]...
[00010334][01 00] v1.7.2499 -> v1.7.2499
[00010338][01 01] v1.7.2499 -> v1.7.2499
[00010380][03 05] v34.1.0.5 -> v34.1.0.5
[00010414][03 06] v2.0.5.10 -> v2.0.5.10
[00010425][04 00] v1.16.0.76 -> v1.16.0.76
[00010454][05 00] v2.5.6.1 -> v2.5.6.1
[00010465][08 00] v1.11.0.19 -> v1.11.0.19
[00010484][09 00] v1.7.0.3 -> v1.7.0.3
[00010514][11 00] v3.3.0.0 -> v3.2.1.0
[00010574][12 00] v1.3.0.60 -> v1.3.0.60
[00010634][12 01] v1.3.0.60 -> v1.3.0.60
[00010694][12 02] v1.3.0.60 -> v1.3.0.60
[00010754][12 03] v1.3.0.60 -> v1.3.0.60
[00010816][15 00] v1.1.2.0 -> v1.1.2.0
[00010853][17 00] v1.1.0.1 -> v1.1.0.1
[00023364][17 01] device not detected.
[00023382][19 00] v1.0.8.59 -> v1.0.8.59
[00023386]Packet upgrade failed at version checking.
[00010380]========== 2014.01.01 00:00:11 unsynchronized ======
[00010388]Packet [C:\WM610_FW_V01.02.01.00.bin] detected.
[00010393]Packet upgrade start...
[00010400]Packet checking...
[00010409]Done.
[00010415]Version checking[1]...
[00010419][01 00] v1.7.2499 -> v1.7.2499
[00010423][01 01] v1.7.2499 -> v1.7.2499
[00010454][03 05] v34.1.0.5 -> v34.1.0.5
[00010494][03 06] v2.0.5.10 -> v2.0.5.10
[00010504][04 00] v1.16.0.76 -> v1.16.0.76
[00010553][05 00] v2.5.6.1 -> v2.5.6.1
[00010573][08 00] v1.11.0.19 -> v1.11.0.19
[00010594][09 00] v1.7.0.3 -> v1.7.0.3
[00010613][11 00] v3.3.0.0 -> v3.2.1.0
[00010673][12 00] v1.3.0.60 -> v1.3.0.60
[00010733][12 01] v1.3.0.60 -> v1.3.0.60
[00010794][12 02] v1.3.0.60 -> v1.3.0.60
[00010853][12 03] v1.3.0.60 -> v1.3.0.60
[00010916][15 00] v1.1.2.0 -> v1.1.2.0
[00010953][17 00] v1.1.0.1 -> v1.1.0.1
[00023463][17 01] device not detected.
[00023482][19 00] v1.0.8.59 -> v1.0.8.59
[00023486]Packet upgrade failed at version checking.
2015-4-15
bornish
Flight distance : 91447 ft
United Arab Emirates
This upgrade procedure needs improvement!
I wonder why DJI has decided that this procedure is better than the one used to upgrade Phantoms.
2015-4-15
DJI-Autumn
gybo102 Posted at 2015-4-16 11:56
Module not detected. Might caused by a poor connection. You've tried it for many times, did you try power off the battery, detach and assemble the camera, then reboot Inspire1 to try again? If still failed, you need to contact the NA Support to investigate the issue.
2015-4-15
gybo102
DJI-Autumn Posted at 2015-4-16 12:14
Module not detected. Might caused by a poor connection. You've tried it for many times, did you try ...
thank you, would you be able to tell what modules is not detected? It has been flying fine with no issues. everything works 100%, until the firmware was installed. I have not flown yet.
2015-4-15
gybo102
and looking at the LOG, it shows it did get the updated on the first run, then it went "device not detected" after. is it possible the firmware "broke" that module?
2015-4-15
DJI-Autumn
I need to comfirm.
And I find this. Did it power off during the upgrade process?
2015-4-15
gybo102
DJI-Autumn Posted at 2015-4-16 13:10
I need to comfirm.
No, I let it go till it gave the long annoying beep that never ends every time.
2015-4-15
DJI-Autumn
gybo102 Posted at 2015-4-16 13:15
OK, I got it.
Pls contact NA Support, and send a mail to autumn.a@dji.com as well. I'll inform them about your case. Thanks a lot.
2015-4-15
mattd
Ok gybo102, the update that didnt update is
Vision Positioning System M0 02.00.00.01 NEW
The inspire 1 needs to know the distance from the floor as this is how it knows when to stop. Looks like the firmware is corrupt or it has issues on that chip.
2015-4-16
123Next >
