Agent Sgt. Shadow
Flight distance : 500679 ft
Skymax2 Posted at 2018-1-31 14:15
That's a good Backpack and value. The Mavic and controller are well protected and I like not having to assemble the Goggles every use. my only question is how much protective padding is around the Goggles? If not much is there room to add some foam? Thanks.
There is a thick, soft layer of foam, and the DJI Goggles are strapped on to the bag, with 2 Velcro pieces. It's hard to explain that part, it's easier to see/visualize. And because you don't have to deassemble your goggles, you can add foam/other things in the middle of the goggles. Again, it's hard to explain. Sorry. I probably should take some pictures next time. |
