Signal lost in a few seconds, is it normal?
611 7 2017-12-21
Ivanski
Flight distance : 714977 ft
Hi guys,
I tried to do a range test today. And somehow the signal lost in about 2200m in just a few seconds.
Just wondering is it normal? You can check the video in 5:40. All signal lost in 5 seconds???!!!
2017-12-21
Trailblazer5715
Flight distance : 1821880 ft
It appears the terrain got between you and the aircraft. It also appears the RTH functioned correctly.
2017-12-21
M.C. Pilot
Flight distance : 10278435 ft
Typically from my experience is if the copter is way out there or signal being blocked by an object. Both of which I worked my way out with altitude adjustment.
2017-12-21
Lucas775
Flight distance : 50642090 ft
The AC and RC have to have a clear visual connection they don't work through GPS.
2017-12-21
Ivanski
M.C. Pilot Posted at 2017-12-21 05:27
Thanks for you advice. I will try next time.
2017-12-21
Boardtalk
Flight distance : 209642 ft
OMG, did you nearly crap yourself? And the RTH came so close to the hill, phew!
Delighted it all worked out for you and you got your drone back. The video was very entertaining watch as I know I wouldn't be so brave.
2017-12-21
Ivanski
Boardtalk Posted at 2017-12-21 14:30
Yes, it's pretty scary when the image just got back. I canceled the RTH immediately.
I should have set the RTH height higher. I set 50m and I should set 80m or more.
2017-12-21
DJI Thor
Flight distance : 13602 ft
Sometimes transmission signal loss might due to the environment interference, or there are objects in the middle of the RC and AC and long distance. In this case, we suggest trying to adjust the antennas, manually fly the drone and avoid the signal block if you can still control it.
For the environment requirement, we suggest flying the drone in an open area. Hope it provides you with some tips. 飞行环境选择.png
2017-12-21
