No verification code shown in DJI Assistant
4866 7 2017-12-22
fansf2859c5c
I cannot log in to DJI Assistant because no verification code is displayed. How can I get this to display?  I have already tried restartring PC, restarting app, etc.
2017-12-22
DJI Thor
Flight distance : 13602 ft
Hi there, please try the steps below:
1. Please check the network connection. Try to login you DJI account on the official website, if you can log in to the official web, then the network is connecting properly, otherwise, it is the network connecting issue;
2. Please help to confirm which version you are using. Please kindly install the DJI Assistant 2 on the Mavic Pro official website.
3. Try to restart the DJI Assistant 2 for several times and see if it works.
4. If it doesn't help, please help to export the log and we will help to check. Below's the route:
Mac: :~/Library/Application Support/DJI Assistant 2/log
Windows: \Users\…\AppData\Roaming\DJI Assistant 2\upgrade_log
Thanks.
2017-12-23
djiuser_CAwFlGm
I can connect to this site (forum.dji.com) and dji.com, but the verification code still does not display after many tries. If I enter a make-believe code (any four random chacters) the Assistant displays “Network Error (1-1). Does that error help fnd the cause?
2017-12-24
bobjonesx
I also am having this problem.
2017-12-28
bobjonesx
I am trying to upload the log, but the upload never completes.
Seems to me that everything that has to do with DJI is faulty, frail, malfunctioning.....
2017-12-28
djiuser_lifukranURwR
bobjonesx Posted at 2017-12-28 15:11
I have had the same issue. DJI support is zero help. Their resolution is to disable antivirus/firewall, which is not possible.
2018-3-14
LAMGHARI
Flight distance : 1038698 ft
Morocco
I have had the same issue. And I am using the latest version of DJI Assistant   <DJI+Assistant+2+For+Matrice+2.0.2.exe>
2018-7-4
LAMGHARI
Morocco
LAMGHARI Posted at 2018-7-4 06:30
The problems still exist after many attempts (re-run the app ; re-install the app , disable antimalware).
But after I changed to another computer (and using the same .exe file) everything worked perfrectly !
2018-7-5
