Mavic Battery- Broken
2403 10 2017-12-27
Timtron007
I Just got a Mavic for the holidays and last night I charged all my batteries (i.e. 3 in total) and this morning all were fully charged. I flew the drone for the first time today and one of the batteries I did not use shows to have a single dot charge level. I then tried to charge it but when I put it into the hub alone I am getting a red light (i.e. an error message). Am I possibly doing something wrong or is it possible this battery is just defective. Does anyone have experience with DJI and defective Batteries? Thanks.
2017-12-27
4WDaus
Flight distance : 1187257 ft
If you load your flight data into http://airdata.com there is a battery report function there. That may assist in determining the issue.
2017-12-28
Mari
Flight distance : 1308780 ft
Try to charge that battery without the use of the hub... if something is wrong with the hub battery will not be charged...
If battery is fully charged and gives after one day just 1 led... it must be defective... contact your reseller or DJI to get it replaced.
2017-12-28
DJI Thor
Flight distance : 13602 ft
Please try to charge the battery directly by the charger, if it won't get charged, please try if you can power it on with the drone and check the status on the app. If it is unable to power on, please send the battery back and we will help to take care of it. Here is the link to apply the online repair case: https://repair.dji.com/en/SelfRepair/Area. We will do our best to help this out. Thank you.
2017-12-28
Timtron007
DJI Thor Posted at 2017-12-28 03:01
Thanks for the tips. I have not tried it connected to the drone, but I'll see if that fixes it. will post an update later.
2017-12-28
Timtron007
connecting it to the drone doesn't help as it wont power on. I am just going to send it in per DJI Thor's recommendation. Fortunately I have 2 other batteries and I probably just get another one while this one get serviced/replaced. Thanks for the help everyone.
2017-12-28
DJI Thor
Timtron007 Posted at 2017-12-28 11:39
Thank you for the update, hope things will be sorted out soon and you can receive your battery back quickly.
2017-12-29
DLPalmer
This appears to be an old link, is there an updated one? I have 2 Mavic Pro batteries that do not work and would like to see if they are repairable or what.
Thank you.
2018-9-12
DJI Thor
DLPalmer Posted at 2018-9-12 15:20
Thank you.
Hi DLPalmer, so you had tried to charge the battery by the charger directly, right? May I know which LED blinked when you tried to charge it? Please make sure that the batteries are not hot before charging. If the issue persists, you can send the batteries in if they are within the warranty period. Here's the link to apply for the online repair case https://repair.dji.com/repair/index.
2018-9-14
DLPalmer
DJI Thor Posted at 2018-9-14 18:29
DJI Thor,
First battery will not light any LEDs and will not power on Mavic Pro and show no indications when plugged directly into charger.
Second battery , the bottom LED will blink 3 times after depressing the button once. When depressing once then second time and hold to power on, the LEDs will light as though it is powering on but then they go off and then the bottom LED blinks once then the top LED blinks once. Will not power on Mavic Pro. When plugged directly into charger bottom LED blinks fast 16 times.
2018-9-16
DJI Thor
DLPalmer Posted at 2018-9-16 10:43
DJI Thor,
I am terribly sorry for the delay. In your first battery, you can try to keep it charging for over 2 hours. As for the second battery, if it is the LED 1 blinks when charging, you may need to send it in. If you had sent them back, you can provide me with your case number, I will help to keep an eye on it. bb.png
2018-9-23
