Any Ideas? New P4P Obsidian just sits and beeps
1667 12 2018-1-12
BrookStockton
Hey folks,
Got the drone on Christmas.  Its never flown.  When I start it up the fans turn on, the gimbal swivels, the front left arm led goes solid red, the back left arm flashes red/green, the right motors vibrate and produce a loud beep at a approx 1 sec interval.  I was able to connect to the DJI Go 4 app on my ipad and update the software on the drone and remote to the most current version.  I can manipulate the camera with the controller.
I contacted dji tech support three times.  They asked me to update the firmware again with "DJI Assistant" which I was unable to do.  It errored out at 32% multiple times.   I updated again using the ipad.  I dont know where I stand with tech support at the moment other than "someone will call you back"
Any ideas?  Thanks
2018-1-12
RedHotPoker
Flight distance : 165105 ft
You haven't really explained where your problem is?
Have you ever flown other RC models? Did you RTFM? ;-)
If the drone is broken, if it's malfunctioning, it will need repair or replacement.
So, you will likely have to create a repair ticket, unless you can return it to the seller and exchange it.
Have you tried to fly it? What are your concerns?
Please post a short video of the motor squeeling. Thanks.
Not sure where else to begin...
RedHotPoker
2018-1-12
BrookStockton
RedHotPoker Posted at 2018-1-12 21:05
Here is a YouTube video of another phantom 4 doing the same thing as mine.
I have flown other drones but not extensively.  I did RTFM but nothing covered the drone being unresponsive and just beeping.  Maybe I missed the troubleshooting section.   I did take a dartdrones class but nothing like this was covered.
Basically I’m trying to make sure there isn’t something I’m doing wrong here.
2018-1-12
PGM
Flight distance : 57146 ft
Thanks for the video footage. That's not good. I see that none of the indicator lights are lighting on the bird., ESC or firmware update error are my first guess but without further analysis, it’s hard to say for sure.
2018-1-12
Jenee 2
Flight distance : 7852129 ft
BrookStockton Posted at 2018-1-12 21:42
https://youtu.be/KYRR21XCKLQ
That sounds like an ESC error. If you connect everything up and turn it all on, RC first, then open the app, then turn on the Phantom and you might see an error message appear in the app.
2018-1-12
DJI Diana
Flight distance : 2408 ft
Could you please refer to the steps Jenee mentioned to check if there is an error message in the APP? When did this issue start and did anything happen before? Besides, what error code have you got when you failed to upgrade the firmware? Could you please provide me some screenshots?
2018-1-13
Antonio76
Flight distance : 144403 ft
Denmark
Front left solid red, back left flashes red/green, what about front right and back right? Both off, or?
2018-1-13
ALABAMA
Flight distance : 10442687 ft
Send it back.  No way this should be happening.
2018-1-13
Rodger8
Flight distance : 20145135 ft
Time for Doctor DJI
2018-1-13
RedHotPoker
Yes, it needs surgery... DJI technicians are trained in this procedure. ;-)
RedHotPoker
2018-1-13
BrookStockton
Thank you all for your replies.  Exchanged as defective
2018-1-13
chips34
Flight distance : 73553 ft
I was sure hoping someone found the problem, mine crashed and replace a bunch of parts and sounds just like mine......hoping for some answers somewhere...
2020-5-12
fans3a1f98f7
Flight distance : 207982 ft
Me too, any feedback outside of sending it back to Dji would be awesome, thanks!
2021-1-8
