My camera/gimble points left slightly
3233 17 2018-1-16
Geekslayer
Flight distance : 182385 ft
Not sure what happened to my post. I just bought a Phantom 4 pro last Sunday. One thing that has troubled me is that my camera/gimble points left about 4 degress. I calibrated the gimble a few times and doesn't seem to make any difference.
Is there a way to fix this, or do i need to exchange it ?
-thank you !
2018-1-16
Punchbuggy
Flight distance : 483166 ft
A hard hit in transit may have mis-aligned the gimbal mechanism. Try:
With all gimbal constraints removed and craft powered OFF,  gentle turn the gimbal on its X axis (left-right) to each side extremity, focusing on the side it's facing away from;
Power everything up, tilt the craft back on it's hind prop arms so that the camera is then pointing 45 degrees up;
Use the DJI GO 4 app to do a gimbal calibration.
If it isn't looking better, then try another gimbal calibration while it's sitting back as normal.
2018-1-16
Dublinphantom
Flight distance : 1033222 ft
A new option is now available on the app. When you have the Drone on and connected, you can go into gimbal settings and simply adjust the gimbal in increments to the right or left as desired. its that easy. no need for anything drastic at all.
2018-1-17
KedDK
Flight distance : 1133038 ft
Denmark
"Not sure what happened to my post"
What post, this one? it is in the Service section.
I think a lot have this problem, also mine is doing it, no calibration fix it for me. Due to other issues i have to send my P4P back (again) for rep.
2018-1-17
Dublinphantom
The video below shows how to adjust the gimbal levels. it can be done from within the app and no need for extreme measures
2018-1-17
johnsr
Flight distance : 1579022 ft
Sorry, but I don't have a P4, however on the P3P gimbal there is a set screw which tightens on a flat section of the vertical shaft. This can loosen (crash, transport) causing the shaft to seat off-axis and could be the problem if there a similar system for the P4. I have attached a photo below for the P3P, maybe someone with P4 expertise could comment.
P3P gimbal
P3P gimbal
2018-1-17
Geekslayer
Punchbuggy Posted at 2018-1-16 22:24
Thanks for your help, but it didn't seem to fix the issue.
2018-1-17
Geekslayer
Dublinphantom Posted at 2018-1-17 00:48
https://www.youtube.com/watch?v=QavkwJ3HTqA
#3 and #5, the horizontal is fine. My problem is like driving a car forward, and then turn your head left 4 degrees while driving.
2018-1-17
Dublinphantom
ah ok. Then maybe try what the others suggest or look on youtube maybe theres a solution there. Sorry I couldn't help anymore
2018-1-17
Aardvark
Flight distance : 384432 ft
Why don't you use the yaw adjustment in DJI Go 4 under "Adjust Gimbal" tap on the greyed out 'yaw' to the right of 'Roll' ?
See Here
2018-1-17
iFoxRomeo
Flight distance : 1094856 ft
Aardvark Posted at 2018-1-17 11:38
See Here
There is no yaw adjustment in my ios GO4 4.1.22Only tilt.
Calibration with the drone pointing upwards, helps only for one or two flights. The misalignment reappears.
Fox
2018-1-17
Aardvark
iFoxRomeo Posted at 2018-1-17 12:05
I've just remembered I think it may be iOS version only.
Edit:- I've just checked this on my Android Nexus 7 MkII (2013?) and it is there too.
2018-1-17
Aardvark
Have a look at this P4P post Here
2018-1-17
eman_vg
Flight distance : 1015440 ft
You can adjust the gimbal tilt on the DJI Go 4 app under gimbal settings. Just go digging and find it
2018-1-17
Geekslayer
eman_vg Posted at 2018-1-17 14:16
Tilt = Yes
Yaw = No
thanks for the help though
2018-1-17
iFoxRomeo
I know where the setting should be, but its not there
2018-1-17
Aardvark
iFoxRomeo Posted at 2018-1-17 14:38
[view_image]
Which firmware are you on ? It's certainly is available on P4P as per my link above.
2018-1-17
DJI Elektra
Geekslayer Posted at 2018-1-17 03:38
Sir, did it turn its head left 4 degrees when you put your drone on the desk? Please provide a picture or video of the camera.
2018-1-21
