CycleParadise
Flight distance : 385338 ft
DJI Thor Posted at 2018-1-18 18:33
How about the connection between your phone and RC with the left USB port? Will it also exist the same case? If it is convenient, I would like to have a video of this case, please kindly focus on the charging side. For your question, if the USB port is loosened, there might be a bad connection between the port and the cable, which means it might disconnect the app if the connection fails.
Since the beginning, around October 2017, I had issues with disconnects when connecting my phone on the left side of the controller. When I use the bottom USB port to connect my phone to the controller, I don't experience disconnects while flying. Ever since then, I use the bottom USB port when flying and use the left port to charge the controller.
I didn't notice the charging problem until today. And that's when I thought that maybe that's what's causing the disconnect issues. Maybe others are experiencing the same.
I'll be more than happy to get video. I can get video of the intermittent charging with the left side of the controller. I can get some video of connecting the phone to the left side of the controller. I haven't tried that in a while but expect to see the app disconnect. Is there anything else you want me to video?
Finally, using the left port on the controller is the only want to charge the controller, correct?
Thanks for your help. |
