Can not push the button on TX to take photo or filming
520 5 2018-1-22
ngonhathoang
Flight distance : 37851 ft
Vietnam
m600 and gimbal is ok, camera connected to the TX controller with the image but can not push the button on TX controller to take the photos or filming. Any one know about this pls help. Many thanks.
2018-1-22
HyperSpectral
Flight distance : 839160 ft
do you have the GCU (gimbal control unit) connected to the IMU/A3.
Do all functions work, tilt, roll, yaw on the gimbal but shutter does not? or does none of it work
2018-1-23
ngonhathoang
Vietnam
HyperSpectral Posted at 2018-1-23 06:31
HyperSpectra: All it work only the shutter is not
2018-1-23
HyperSpectral
ngonhathoang Posted at 2018-1-23 07:08
Connect the system to DJI Assistant 2 and check the SDK page where you can assign channel mapping. Try to see if changing the shutter setting helps, other than that maybe check the gimbal application? Depends on what kind you have, but there's a downloadable installer on the DJI website if it's a Z-15 as an example
2018-1-23
ngonhathoang
Vietnam
HyperSpectral Posted at 2018-1-23 07:20
Thanks I was try, but im using ronin MX with sony A7R2 not Z15, do you think is any problem with iR trigger?
2018-1-23
HyperSpectral
ngonhathoang Posted at 2018-1-23 14:09
It's possible, it could be your camera too. Make sure the Camera is ready to accept and take pictures with IR input.
2018-1-23
