Firmware upgrade has stalled!!
1335 6 2018-1-25
JJ Wright
Flight distance : 162244 ft
Hi all, went to start up my Mavic this afternoon and DJ Go 4 indicated a firmware update is required .... strange because I did a firmware upgrade via DJI assistant the other day.
Now it seems to have stalled at 56%. I'm connected via the controller and my iPhone 7 Plus. It's been over 10 minutes now and battery is starting to drain.  Is it okay to stop and try again without hurting anything?
2018-1-25
S.D. Pilot
Flight distance : 10278435 ft
Try using DJI Assistant 2 - for Mac or PC - anytime the app device stalls, I use the A2
http://www.dji.com/mavic/info#downloads
2018-1-25
JJ Wright
S.D. Pilot Posted at 2018-1-25 15:04
After 20 minutes I gave up and restarted, with fresh battery. Once Mavic and controller started and connected, DJ Go 4 indicated that firmware had downloaded so I started update again. It was slow and stalled again at around 56%, but after a few minutes resumed very slowly and finally finished. What concerns me is why it needed firmware update after I upgraded via DJI assistant 2 days ago. Thought maybe controller neede update!
2018-1-25
S.D. Pilot
JJ Wright Posted at 2018-1-25 15:53
Yea sometimes I guess it doesn't download/sync as it should. It's happened to me on a couple of occasions. Just make sure the Mavic to directly connected to the computer and RC is turned on. Once DJI A2 is connected to the drone and uploading FW, the RC will be wirelessly updating as well.
2018-1-25
JJ Wright
S.D. Pilot Posted at 2018-1-25 16:25
Hmmm, wasn’t aware that controller updated while using DJI assistant on the bird itself.
2018-1-25
S.D. Pilot
JJ Wright Posted at 2018-1-25 16:46
You'll noticed the beeping, telemetry dash on the RC also go on/off.
2018-1-25
DJI Elektra
Sir, please provide me the screenshot of the firmware info. Thanks for your support.
2018-1-26
