Ex Machina
![](https://forum44.djicdn.com/data/attachment/common/9b/common_15_usergroup_icon.png) First Officer
Flight distance : 1806362 ft
KnightVision Posted at 2018-1-27 06:28
disregard the first part of reply 11# (this damn site won't let me delete the reply) since Ex Machina did also suggest that it could be dust or condensation. going by the stubbornness of the stain I'm betting it's probably condensation, and I suspect it's on the sensor. I'll try and see if I can clear off anything that could be on the outer lens itself, if that doesn't do anything I'll probably send it off to be looked at. If the problem clears I'll let you all know
Heh, you might not be able to delete or edit posts until you've "leveled-up" with more posting. The function is under Edit on your post and then Additional Options. Good luck. |
