Grey bars through images. Please help.
980 7 2018-1-27
Arrant
Hello. I have a brand new p4 advance. I have grey bars and strange still images. Happens in every photo when flying, never happens inside. Good connection and my monitor looks perfect.
Often when taking stills there is a delay like its thinking.
Image's from sd card.
Thanks for any help.
2018-1-27
Arrant
Also I don't think it's taking all pictures. I took around 10 but it only put 5 on ad card. And I tried taking a video while flying and it said it was to short to load on computer it wouldn't load. It was 230mb in size 1080p.
2018-1-27
Blériot53
Flight distance : 6188465 ft
One observation I make is that the filesize for the two images is identical.  Is there some limiting factor which is preventing the storage of larger filesizes?  It;s pretty unusual for two to be identical in size - are the others the same size too?  Are they perhaps the thumbnails rather than the actual pictures?
2018-1-28
Peterx
Flight distance : 1499708 ft
These 2 pictures are written as truncated infos  for the colors of the pixels  in that parts of the gray bars. Does the card has sector errors ? Did you check the card for errors yet?
2018-1-28
DEUCEDOG
Flight distance : 2501575 ft
What make and size of card are you using ?
2018-1-28
KedDK
Flight distance : 1133038 ft
Denmark
As written between the lines in other replies it look like your card is not fast enough for the job.
If it has worked before and a reformat don't solve it the card might has got a defect.
2018-1-28
Peo
Flight distance : 25409793 ft
Sweden
Jepp, probably the card, I run with a Samsung 64 EVO
2018-1-28
Arrant
It's the card that came with it. SanDisk extreme.
I could have accidentally uploaded the thumbnails by mistake.
How come it seems to take good pictures inside but not when flying?
I'll try to reformat card and give it a try.
2018-1-28
