video only working for a few minutes
686 10 2018-2-1
fans3db2e24a
South Africa
The Phantom 4 stops filming after a minute or two. I have formatted the card and ensured that I do not accidentally touch any buttons and so on whilst filming but it stops everytime - any ideas please?
2018-2-1
Bashy
Flight distance : 2354357 ft
Could be that the memory card is just not good enough?
2018-2-1
DJI Susan
Hi there, may I know which SD card do you use? The SD card of poor quality may affect recording. If you still keep the original SD card which comes with the drone, I'd suggest to verify.
2018-2-1
fans3db2e24a
South Africa
DJI Susan Posted at 2018-2-1 22:29
what do you suggest that I use. it only films for about 30 seconds to 1 minute
2018-2-2
fans3db2e24a
South Africa
The card is a san disk ultra which shouuld suffice
2018-2-2
ALABAMA
Flight distance : 10442687 ft
Scsndisk extreme are the best.
2018-2-2
DEUCEDOG
Flight distance : 2501575 ft
fans3db2e24a Posted at 2018-2-2 05:31
i had the same happen to me and i was using a sandisk extreme , turned out to be a fake and you could'nt tell the difference .....bought it from an online store beginning with A  .  where did you get the card from ?
2018-2-2
fans3db2e24a
South Africa
DEUCEDOG Posted at 2018-2-2 07:35
Thanks. I bought it from a camera dealer so should be authentic
2018-2-2
Geebax
fans3db2e24a Posted at 2018-2-2 07:42
Sadly, that does not mean it will be authentic. First thing is to buy a Sandisk Extreme series card, the Ultra series are on the borderline of being too slow. I never skimp on having the fastest Sandisk cards, and I have never been let down.
2018-2-2
fans3db2e24a
South Africa
Geebax Posted at 2018-2-2 13:50
Thank you. I tested the slower speeds and yes the card records at very slow speeds so I will invest in the Sandisk Extreme.
2018-2-2
DJI Susan
fans3db2e24a Posted at 2018-2-2 20:32
In theory, it supports Micro-SD cards with Class 10 grade or above and write speeds above 60 Mbps (Note the write speed. Normally average, max. write speed or read speed is labeled in products). Please keep us posted on the latest progress, thanks!
2018-2-5
