Phantom 3 4K - "Command timeout" on every aircraft command
2670 8 2018-2-5
fansbef6fd77
Flight distance : 33 ft
Brazil
Same issue here. I updated the firmware 2 months ago, flew a couple times flawlessly and then had a brake of about 3 weeks and the issue started.
I turn AC and Radio on then open DJI Go App, camera connects, AC warms up fine, AC lights blink green, app says "Ready to Go"  yet..
ALL COMMANDS TIME OUT. Can't take off, can't set max altitude, can't change flight mode, can't set max distance. I've already tried:
- use different devices (Android and iOS);
- clear app cache and data on different devices (Android and iOS);
- reinstall the app on different devices (Android and iOS);
- relink the radio.
This is the info on the "about" menu:
DJI Go App version: 1.5.40+
AC Firmware version: 3.1.11
Flight Controller Serial No.: N/A
At first I'd get no GPS signal even outdoors in wide open areas away from WiFi, radio antennas, electrical wires and etc. Then I opened the AC, disconnected the GPS module and started the AC without it. I expected it to throw some kind of "GPS module error" on the app, but it didn't change the behavior. Still goes on, still warms up, connects to the radio, to the app, image shows up fine, can control the gimbal angle, record and take pictures, but every control relative to the AC times out. I reassembled it and now I'm able to get GPS signal, but it still won't take any AC commands.
Is there any debugging software or debug logging mode I can use to get any clearer info on this?
2018-2-5
stuka75
Flight distance : 85682 ft
Not clear on your startup sequence, but proper sequence is controller, ac, open app etc. Try force closing the app, and any other flight apps you may have on your phone/tablet. Force closing thorough the settings menu has clear up occasional  hiccups I"ve had on startup.
2018-2-5
Nebuchadnezzar
Flight distance : 3462946 ft
You can try "plane mode " to avoid internal process from others apps
2018-2-5
DJI Susan
Hi there, just to verify, can the drone been started by CSC without APP? If not, I'm afraid that you may consider to send it in.
2018-2-5
fansbef6fd77
Brazil
stuka75 Posted at 2018-2-5 09:14
I've tried all of that. Nothing changes the outcome.
2018-2-6
fansbef6fd77
Brazil
DJI Susan Posted at 2018-2-5 23:07
CSC isn't working as well. I've been able to CSC one time since it started, but it was pretty random. I had been trying to get it to take off for more than an hour, then it suddenly started responding. I flew it for around 5 minutes, then it started behaving erratically, like it was constantly losing/locking radio signal.
2018-2-6
DJI Susan
fansbef6fd77 Posted at 2018-2-6 07:26
Sorry about this. Please kindly start a case and send it in: https://www.dji.com/support
2018-2-9
Indiana Djanho
Brazil
DJI Susan Posted at 2018-2-9 01:40
Hi Susan!
I just went over the support page and I guess the easy way would be submitting a Repair Request, right? Thing is I live in Brazil and requesting it online is not available here.
Luckily there is a Recommended Service Center in my city (Curitiba, Brazil). Best case scenario, they can repair it; but if not, will they be able to replace the aircraft?
Thanks in advance.
2018-2-9
DJI Susan
Indiana Djanho Posted at 2018-2-9 04:45
Hi Susan!
Thanks for getting back to us. Please try to contact the dealers to see whether they can help. Generally, the dealers will report in dealer system if they cannot handle it, the designated team will take care.
2018-2-25
