Video transmission keeps lagging
1805 11 2018-2-8
gmota_23
Portugal
My Phantom 4 using the DJI GO 4 app, the image keeps lagging.
iPhone 6 Plus.
On my brother's iPhone 6 Plus and my dad's iphone X it doesn't do that.
2018-2-8
fansb885c69e
Flight distance : 349419 ft
Is your firmware up to date? I found the last update fixed this for me.  (iPhone 6s)
2018-2-8
gmota_23
Portugal
My firmware is up to date.
2018-2-8
dronybaloney
Flight distance : 26656122 ft
Please see this thread , i have the same issue with ipad mini 4.
It apparently depends what kind of chip is the device . You need at least an a8x chip. I even have a8 and you can see my example clip , has got the same you have.
I bought now ipad pro 10.5 and hope to test this coming
https://forum.dji.com/thread-133969-1-1.html
2018-2-8
Aardvark
Flight distance : 384432 ft
You say firmware is up to date, is the RC at V1.9.3 ?
This can be checked by looking at 'About' in 'General Settings' menu.
2018-2-8
gmota_23
Portugal
Aardvark Posted at 2018-2-8 13:35
It is: RC at 1.9.3, drone at 02.00.0700
2018-2-10
Aardvark
gmota_23 Posted at 2018-2-10 05:37
Try deleting and reinstalling DJI Go 4 on your iPhone 6 plus.
And the firmware on your phone at latest iOS 11.2.5 ?
I've read in the past where a backup and recovery of device using iTunes has helped, whether that points to some anomaly in iOS I do not know. But if all else fails may be worth considering.
2018-2-10
Rafa-Rebelo
Flight distance : 594475 ft
Brazil
My Phantom 4 using the DJI GO 4 app on my ipad, when I am at 1500 meters the image hangs and the signal loss message appears. This message appears in open areas and without interference from magnetic fields. Can someone help ?!
Thank you!
2018-2-11
fans02010415
Flight distance : 2106358 ft
Rafa-Rebelo Posted at 2018-2-11 17:38
Thank you!
I had the same problem of video transmission issues with the RC firmware version 1.9.3.  I was advised to resort back to a previous version of this firmware.  Loaded 1.8 and the problem was resolved.  All of this with the latest AC firmware installed.
Hope this helps
2018-2-16
fans48d4fe5a
Flight distance : 1313419 ft
fans02010415 Posted at 2018-2-16 12:57
Hope this helps
How did you downgrade rc firmware to 1.8.0? When I select 1.8.0 and do a firmware refresh it does not stick. After restarting the rc it shows I still am on 1.9.3...Thanks!
2018-2-16
fans02010415
You might have to reload the DJI Go 4 app  and then revert back to the RC firmware version 1.8
2018-2-17
fanscf5de830
Flight distance : 1023320 ft
You may want to delete the app from your phone turn the phone off .Turn phone on and reinstall the app. It worked for me. Good luck.
2018-2-17
