dark spots.. anyone else having this problem
4525 16 2018-2-11
Peter Powers
Flight distance : 113773 ft
Finland
Hey everyone,
after quite some adventure my mavic air finally arrived last week, and I took it out for the first time today - I did enjoy the experience of flying with it,
but when I came home and checked my photo/video footage, it all has a darker spot on the upper right side.
I did check the lens for dirt, and it looked clean, i grabbed a microfiber lens cleaning cloth, and cleaned it anyways,
just to make sure, but when I turned it on, the dark spot was still there.
has anyone else experienced this Problem, and if so found a solution?
best regards,
PP
PS: attached some pictures which show the problem, those pics are edited only for the size, so the forum would allow the upload.
2018-2-11
Jeff7577
Flight distance : 1916821 ft
Try taking a photo of the sensor with a good camera and zoom way in to see if there is debris. It must be under the glass.
2018-2-11
A CW
Flight distance : 14177772 ft
This looks like some sort of smudge or debris on the inside of the lens - you'll need to send it back for replacement.
2018-2-11
eYeSkYeYe
This is not good. Looks like your MA was made during the sand storm so some of debris stuck somewhere in the camera... potential places are lens and sensor.
2018-2-11
Peter Powers
Finland
Jeff7577 Posted at 2018-2-11 08:59
mh, i just tried to do that, but i guess my little rx100 aint good enough for that - can't see anything but shiny colors from the light reflections
2018-2-11
Peter Powers
Finland
A CW Posted at 2018-2-11 09:01
damn there's no way to clean that myself?
as I mentioned, getting the drone to me was a bit of an adventure, and if i send it in, getting it to me again might be even harder (I'm currently traveling a lot).
My insurance is probably not going to like when i ask them to switch back to the sparks S/N as well
well, i guess i'll have to contact DJI's support on Monday then, thanks for your answers.
2018-2-11
TomFI
Flight distance : 3416575 ft
Finland
I have a dark spot in Mavic Pro.  It is disturbing only in wintertime so I did not claim a replacement during warranty time.  Any idea if DJI could replace the camera after warranty or do I have to accept this is just bad chinese quality control?  Here is some footage: https://www.facebook.com/aholato ... 5/10216546853358289
2019-2-11
Ex Machina
Flight distance : 1806362 ft
Peter Powers Posted at 2018-2-11 09:20
If the spot goes away, then it could be condensation. If it persists, then it is mostly likely dust on the sensor.
Condensation problems will go away with temperature equalization, dust hardly ever dislodges from the sensor and has to be returned for replacement.
Luckily you're under warranty, but see if the problem persists before sending it back. Good luck.
2019-2-11
Ex Machina
TomFI Posted at 2-11 13:07
I have a dark spot in Mavic Pro.  It is disturbing only in wintertime so I did not claim a replacement during warranty time.  Any idea if DJI could replace the camera after warranty or do I have to accept this is just bad chinese quality control?  Here is some footage: https://www.facebook.com/aholatom/videos/o.692554524231005/10216546853358289
Ugh. Shame you didn't notice this before the warranty expired -- guess you could throw yourself on the mercy of DJI support and see what happens. Good luck.
2019-2-11
HedgeTrimmer
It looks like a dust spot.  I don't know of any easy way to clean drone's camera assembly.   Not easily opened and very small to work on.
Whereas on DSLR with removable lens, you can buy sensor cleaning kits.  And with a delicate touch, clean fragile thin glass plates (filters) that cover actual sensor.  A cleaning skill needed more with mirror-less cameras that have removable lens.
2019-2-11
TwentyThrill
Flight distance : 257133 ft
The ring/lens of the Mavic Air is unscrewable just as like a bottle cap, try to remove it and give it a clean from the inside.
2019-2-11
Ex Machina
TwentyThrill Posted at 2-11 16:32
[view_image]
Thats not actually removing the lens and exposing the sensor, is it? I thought that was just a protective glass that can be replaced with density filters.
2019-2-11
TwentyThrill
Ex Machina Posted at 2-11 16:56
You're right, is just a protective glass, but if he's lucky the dust dot could be inside there, is worth to check.
2019-2-11
Ex Machina
TwentyThrill Posted at 2-11 17:45
Agreed, worth a shot.
2019-2-12
JVN
Brazil
Hello. did you solve the problem ? I jhave the same.
2019-2-25
JVN
Brazil
2019-2-25
djiuser_mcseC5hpbUXl
Nepal
I had this problem in my mini 2.
You can remove it by pushing the lens forcefully downwards and the lens will start to vibrate and to stop it touch the lens ... Do this for some time and your dark spot will be removed.
2020-12-28
