Mavic Air charger not charging in parallel - drawback or advantage?
1951 12 2018-2-16
achim1989
I finally got my Air yesterday and, because I'm good customer, I read the manual and charged all batteries before usage. While doing so (or better while watching the charger do so) I noticed that, although it has four slots, it is charging the batteries one by one (or is there a switch to change that?). And I found that odd at first. But then I got thinking and got curious about the opinions of other Air pilots... So what do you think? Advantage or Drawback?
Single SelectVote, Total 18 people participate in voting View Poll participants
Voting has ended
72.22% (13)
27.78% (5)
Your user group with no voting privileges
2018-2-16
lovec1990
Flight distance : 36158 ft
Slovenia
Iits a limitation there is a limit how much current can come from electrical socket to charging hub so charging one fast then next one or charging all 4 slow
2018-2-16
LoSBoL
Flight distance : 666483 ft
Advantage for me personally, not just for the quickest way to get in to the air again, but also because I'm going to use a car charger on a motorbike, and I'd be worried that fast charging all batteries at once would be way to much for the electric circuit of the bike to handle.
2018-2-16
DJT_MVSP
Flight distance : 2018645 ft
Singapore
The spark's batteries are only 20 watts while the Air is 50 watts
A much more powerful transformer is needed to simultaneously charge all four batteries at once which will emit lots of heat (which will require a fan)
I think it's just good the way it is right now..
2018-2-16
rantanlan
Flight distance : 69698 ft
I don't get while you all see this as an advantage? Okay, formfactor of the power brick might be an issue, but if I'm on a remote location I don't want to sit at the socket for next to 3 hrs until I can fly again. and the "current from the socket" argument is a little strange, you can draw way more power from one socket.. sure you need different components in your charging pcb and stuff... but it's just a lazy excuse in my eyes.
2018-2-16
Cameleon
Flight distance : 60394 ft
I don't mind it how it is as it means you don't need either a bigger power brick as standard or have to buy a bigger one with the hub.
Would have been a nice option they had some kind of dual mode on the hub where you could buy a beefier charger and it would allow all 4 to be charged together or use the standard charger and just do one at a time.
2018-2-16
Montfrooij
Flight distance : 2560453 ft
Better this way. You will get into the air sooner
2018-2-16
LoMackz
Flight distance : 183704 ft
Sweden
Yes, better
2018-2-16
Mavic Ace
Flight distance : 333976 ft
The MPP charges in the same fashion.  It charges the battery with the most charge first and then moves down the line.
2018-2-16
A CW
Flight distance : 13926112 ft
I have the DJI Advanced charging hub for my MPP - when the first battery hits around 85% it starts charging the next one simultaneously - charging 4 batteries from 15% to 100% knocks a whole hour off the total charge time using the same charger and is also compatible with the P4 charger halving the total charge time - great accessory!
2018-2-16
hallmark007
Flight distance : 9827923 ft
It’s six of one and half a dozen of another, dji might release another charger for MavAir which will power up all 4 batteries together, we’ve seen this with other dji drones.
2018-2-16
Montfrooij
A CW Posted at 2018-2-16 12:11
So that is different from the 'standard' charging hub.
2018-2-16
A CW
Yep - it also has an internal fan to keep it cool when using the 100w P4 charger - 2.5 hours to fully recharge 4 MPP batteries from flat! You can’t use the P4 charger on the standard hub - another reason not to get the MP flymore combo imo
2018-2-16
