P4P - USD or GBP - FCC or CE
743 12 2018-2-22
GDS
Flight distance : 589393 ft
Thailand
OK, if anyone can assist.....
1) Is it possible to order from DJI, specifically a CE compliant P4P remote controller? I see nowhere to specify which type when ordering.
and 2) is a rant.... Controller price in US$ = $319.
Controller price in GBP is £319.
£1 = $1.38  So, here in the UK, I would be paying $440 for the same controller
2018-2-22
SM-17
Flight distance : 179288 ft
Regarding the ce, fcc they are the same controller, it's the gps that stipulate weather to use ce or fcc, depending on the country you are in when switching on the controller
2018-2-22
Labroides
Flight distance : 9991457 ft
No because it's the same controller and it adjusts output to match your location.
2018-2-22
GDS
Thailand
Aha, OK understood.
So, is there a way to check for sure which one is correct for Thailand? I am guessing FCC, but I want to run in lower power CE. Is there a controller mod available to achieve this?
Edit: Also, is there a way to find out what the P4P Aircraft transmitter power is on a P4P? It's not listed in the specs like for the Mavic/Spark.
Many thanks.
2018-2-22
SM-17
In ce it's 0.09W
In fcc it's 0.4W
2018-2-22
GDS
Thailand
SM-17 Posted at 2018-2-22 06:07
In ce it's 0.09W
In fcc it's 0.4W
So, are all P4P’s the same and is the  transmission output power of the bird set and controlled by the FCC/CE version of the controller (which I understand is set by GPS and location)?
And Thailand ‘s location sets the controller to FCC or CE?
2018-2-22
Aerial-Image
Flight distance : 1452408 ft
They are ALL the SAME . - Your locations when using it changes power setting to FCC or CE - used in Thailand would make it a FCC (full power) version - used in UK it would make it a CE reduced power version
2018-2-22
SM-17
Using fcc is not the full power the controller is capable off, it can handle 1.5W. (but monitor the rules of your country, so you don't break any rules)
2018-2-22
GoldenSun
Flight distance : 681903 ft
Poland
LOL don't be surprised with the price in different currencies, take the Mavic Air for example: USD $ 799, while in EUR it's € 849.
1 EUR = 1.23 USD, so not only are you paying more, you're paying more twice! - one because of the number, and two because euros are more expensive than dollars...
2018-2-22
DJI Susan
As far as I know, Thailand takes CE in 2.4GHz and FCC in 5.8GHz for reference. Also, due to the warranty is not international, it is recommended to purchase from local authorized dealers: https://www.dji.com/where-to-buy
2018-2-23
GDS
Thailand
DJI Susan Posted at 2018-2-23 00:07
Thanks DJI Susan, that's interesting.
On the Thai Drone Registration form, we have to state the transmitter power (EIRP) at:
1) 2.400 - 2.483 GHz
2) 5.725 - 5.825 GHz
It would be helpful to me and many others if you could you please give the 2 OFFICIAL powers (dBm) at which the transmitter operates in THAILAND at EACH of the 2 frequencies. Something that can be quoted to the authorities.
If what you say is correct, even though the controller is stamped FCC, the equipment is operating WITHIN the allowed power range (of up to 20dBm in the 2.400 - 2.483 GHz range). Clarification of that would be HUGE!
2018-2-23
Eric13
Flight distance : 13982031 ft
GDS Posted at 2018-2-23 00:27
You can find it here:
https://forum.dji.com/forum.php?mod=redirect&goto=findpost&ptid=75955&pid=606456&fromuid=583619
2018-2-23
GDS
Thailand
Eric13 Posted at 2018-2-23 01:13
Thanks Eric,
I've worked out that the controller GPS location sets the transmitter power.
Now I want to know DEFINITIVELY what the controller defaults to in Thailand.
2018-2-23
