RC Controlled Spark Went Haywire Mid Fight
868 8 2018-2-24
Matt08hk
Flight distance : 54888 ft
I decided to do a quick text flight after I have updated to firmware 100.900. All status was normal with only 5 satellite prior to taking off.
Everything seemed normal till it switched to Opti mode due to lack of GPS signal. then the app prompted me I was already at the maximum altitude at only around 100ft and I was limited to a distance of 500m (which doesn't seem to be 500m) while i was flying it with an RC. I decided to have the drone back then all of the sudden it haywire! the drone acted like it was compensating to the wind velocity, but it wasn't windy at all and only at 100ft. I noticed the drone also suddenly switched to sports mode (or at least it felt like it).
Video:
https://drive.google.com/file/d/1Gz3ysjHglxNIfgL9II7_hmi8jZyMse2L/view?usp=sharing
Errors/Prompts I had:
Weak GPS
Compass Error (Calibrated before flight)
Gimbal Overload
Opti Mode
Anyone knows whats going on?
2018-2-24
DJI Elektra
Hi, Matt. Did you crash the drone before? If not, please ensure that there is no interference around your spark. Please try to fly in a place with good GPS signal and fly again. Thanks for your support.
2018-2-24
Matt08hk
DJI Elektra Posted at 2018-2-24 02:29
Hi Elektra,
No I have not crashed before. I did try again in an open field both w/wo OTG. The signal is still a bit odd still but I did not have lost control like the first time.
2018-2-24
Solestacz
Flight distance : 489193 ft
i don't even leave the gound with <12 satellites locked, so that what happened to you does not happen to me. that approach has proven reliably effective. it's just true that there are times/places you really should not fly.
2018-2-24
Matt08hk
Solestacz Posted at 2018-2-24 07:03
I can understand where you're coming from. I wouldn't know how else will i be able to enjoy this spark if I live in a densely tiny populated city and be able to maintain a perfectly disciplined like yourself
2018-2-24
Solestacz
Matt08hk Posted at 2018-2-24 07:36
there are times when i initially get a low gps count, but if i wait 1-2 minutes on the ground, the count will come up to a good # - when it does, i launch and try to get up to a decent altitude (20-30m) straight away - to get out of interference and into a better count of satellites locked - i know- we're all concerned about maximizing flight time vs battery charge, but the patience pays off. some other users who operate in that kind of urban enviro may have some specific tips as to how the approach the situation.
2018-2-24
DJI Elektra
Matt08hk Posted at 2018-2-24 03:01
Hi Elektra,
I see. Please enter wifi setting and check if most of the channels are green. I would recommend you fly with the best signal. Keep us updated, if you find the new problem.
2018-2-27
mattinhk
DJI Elektra Posted at 2018-2-27 01:24
Understood, atm i have sent the drone to the repair service because the gimbal issue is becoming a big frustration. I'll wait for it to be shipped back and give it another go.
2018-2-27
DJI Elektra
mattinhk Posted at 2018-2-27 01:37
I see. I think our designated department will take a good case of your product. Hope you can get it back soon.
2018-2-27
