djiuser_fiQgdFqHaUQg
Philippines
1. In a long distance waypoint mission where the radio feed can cut, if the aircraft gps count gets too low, will it continue doing the mission even if gps gets too low? Can it continue just by the maps memory?
2. In a windy condition waypoint mission, since automation only flies at 20 mph, if the headwind exceeds or slows down automation speed, will the aircraft use more power to maintain 20mph? Will the aircraft try it's best to lock on set course?
3. If it goes way off course from the set waypoints because of a gust, will it go back to the mission route and continue or will it return home?
