Chris - UK
Flight distance : 921329 ft
00m 00s 0.0 ft 0 ft Mode Mode changed to Motors_Started
00m 00s 0.0 ft 0 ft Tip Setting new Return-To-Home altitude to 30m (98 ft). Setting new Maximum Flight Altitude to 5m (16 ft)
00m 01s 0.0 ft 0 ft Mode Mode changed to Assisted_Takeoff
00m 15s 0.0 ft 0 ft Mode Mode changed to GPS_Atti
00m 18s 1.3 ft 0 ft Tip Setting new Maximum Flight Altitude to 30m (98 ft)
A 00m 18s 1.3 ft 0 ft Mode Mode changed to GPS_Atti
B 00m 22s 1.6 ft 6 ft Tip Setting new Maximum Flight Altitude to 120m (394 ft)
C 00m 22s 1.6 ft 6 ft Tip Home Point Recorded. RTH Altitude: 30m.
D 01m 17s 86.0 ft 20 ft Tip High Wind Velocity:Fly with caution and ensure the aircraft remains within your line of sight.
E 01m 44s 76.4 ft 14 ft Tip High Wind Velocity:Fly with caution and ensure the aircraft remains within your line of sight.
01m 47s 49.9 ft 35 ft
80% Battery
F 02m 01s 125.7 ft 247 ft Tip High Wind Velocity:Fly with caution and ensure the aircraft remains within your line of sight.
G 02m 08s 173.2 ft 422 ft Tip Obstacle Avoided. Revise Flight Route
H 02m 17s 263.4 ft 544 ft Warning Attitude is too large., Forwardobstacle sensing is unavailable.
I 02m 26s 359.6 ft 741 ft Warning Attitude is too large., Forwardobstacle sensing is unavailable.
J 02m 29s 360.9 ft 781 ft Mode Mode changed to Go_Home
K 02m 29s 360.9 ft 781 ft Tip Tips__Aircraft is returning to the Home Point. Minimum RTH Altitude is30m. You can reset the RTH Altitude in Remote Controller Settings after cancelling RTH.
L 02m 30s 360.9 ft 787 ft Tip High Wind Velocity:Fly with caution and ensure the aircraft remains within your line of sight.
M 02m 43s 375.3 ft 957 ft Tip High Wind Velocity:Fly with caution and ensure the aircraft remains within your line of sight.
N 03m 07s 329.4 ft 1,399 ft Tip High Wind Velocity:Fly with caution and ensure the aircraft remains within your line of sight.
03m 18s 330.0 ft 1,532 ft
70% Battery
O 04m 06s 297.6 ft 2,357 ft Mode Mode changed to WiFi_Reconnect
P 04m 06s 296.9 ft 2,359 ft Mode Mode changed to Go_Home
Q 04m 07s 294.6 ft 2,369 ft Mode Mode changed to WiFi_Reconnect
R 04m 08s 294.0 ft 2,372 ft Mode Mode changed to Go_Home
S 04m 09s 294.0 ft 2,384 ft Mode Mode changed to WiFi_Reconnect
T 04m 09s 294.0 ft 2,394 ft Mode Mode changed to Go_Home
U 04m 19s 293.6 ft 2,470 ft Mode Mode changed to WiFi_Reconnect
V 04m 19s 293.6 ft 2,472 ft Mode Mode changed to Go_Home
W 04m 20s 293.6 ft 2,482 ft Mode Mode changed to WiFi_Reconnect
X 04m 21s 293.6 ft 2,484 ft Mode Mode changed to Go_Home
Y 04m 24s 292.6 ft 2,509 ft Mode Mode changed to WiFi_Reconnect
Z 04m 25s 292.3 ft 2,516 ft Mode Mode changed to Go_Home
a 04m 29s 292.3 ft 2,534 ft Mode Mode changed to WiFi_Reconnect
b 04m 30s 292.3 ft 2,538 ft Mode Mode changed to Go_Home
c 04m 31s 292.6 ft 2,544 ft Mode Mode changed to WiFi_Reconnect
d 04m 32s 292.6 ft 2,548 ft Mode Mode changed to Go_Home
e 04m 35s 292.6 ft 2,559 ft Data Loss Downlink data connection lost for 1 seconds
f 04m 35s 292.6 ft 2,559 ft Mode Mode changed to WiFi_Reconnect
g 04m 36s 292.6 ft 2,560 ft Mode Mode changed to Go_Home
h 04m 37s 288.4 ft 2,566 ft Mode Mode changed to WiFi_Reconnect
i 04m 39s 288.4 ft 2,569 ft Mode Mode changed to Go_Home
j 04m 42s 287.7 ft 2,566 ft Mode Mode changed to WiFi_Reconnect
k 04m 43s 288.1 ft 2,565 ft Mode Mode changed to Go_Home
l 04m 43s 287.4 ft 2,563 ft Mode Mode changed to WiFi_Reconnect
m 04m 44s 287.7 ft 2,563 ft Mode Mode changed to Go_Home
n 04m 46s 288.1 ft 2,565 ft Tip High Wind Velocity:Fly with caution and ensure the aircraft remains within your line of sight.
o 04m 48s 288.1 ft 2,560 ft Data Loss Downlink data connection lost for 1.4 seconds
p 04m 49s 288.1 ft 2,554 ft Mode Mode changed to WiFi_Reconnect
q 04m 49s 288.1 ft 2,545 ft Mode Mode changed to Go_Home
r 04m 50s 287.7 ft 2,542 ft Mode Mode changed to WiFi_Reconnect
s 04m 50s 288.4 ft 2,535 ft Mode Mode changed to Go_Home
t 04m 52s 288.1 ft 2,523 ft Data Loss Downlink data connection lost for 1.1 seconds
u 04m 52s 288.1 ft 2,523 ft Mode Mode changed to WiFi_Reconnect
v 04m 52s 288.1 ft 2,522 ft Mode Mode changed to Go_Home
w 04m 56s 288.4 ft 2,471 ft Warning Warning:Command Timeout
x 05m 00s 287.7 ft 2,447 ft Mode Mode changed to WiFi_Reconnect
y 05m 00s 287.7 ft 2,444 ft Mode Mode changed to Go_Home
z 05m 03s 287.7 ft 2,421 ft Mode Mode changed to WiFi_Reconnect
A 05m 04s 287.7 ft 2,417 ft Mode Mode changed to Go_Home
B 05m 04s 287.7 ft 2,413 ft Mode Mode changed to WiFi_Reconnect
C 05m 05s 288.1 ft 2,411 ft Mode Mode changed to Go_Home
05m 08s 288.1 ft 2,410 ft
60% Battery
D 05m 23s 287.7 ft 2,389 ft Mode Mode changed to WiFi_Reconnect
E 05m 24s 288.1 ft 2,389 ft Mode Mode changed to Go_Home
F 05m 32s 288.4 ft 2,450 ft Mode Mode changed to WiFi_Reconnect
G 05m 32s 288.4 ft 2,451 ft Mode Mode changed to Go_Home
H 05m 33s 288.1 ft 2,459 ft Mode Mode changed to WiFi_Reconnect
I 05m 34s 288.1 ft 2,462 ft Mode Mode changed to Go_Home
J 05m 40s 289.0 ft 2,501 ft Mode Mode changed to WiFi_Reconnect
K 05m 40s 289.4 ft 2,506 ft Mode Mode changed to Go_Home
L 05m 50s 287.4 ft 2,623 ft Mode Mode changed to WiFi_Reconnect
M 05m 50s 287.4 ft 2,624 ft Mode Mode changed to Go_Home
N 05m 54s 288.1 ft 2,687 ft Mode Mode changed to WiFi_Reconnect
O 05m 55s 287.7 ft 2,691 ft Mode Mode changed to Go_Home
P 06m 09s 288.1 ft 2,920 ft Data Loss Downlink data connection lost for 1.9 seconds
Q 06m 09s 288.1 ft 2,920 ft Mode Mode changed to WiFi_Reconnect
R 06m 09s 288.1 ft 2,933 ft Mode Mode changed to Go_Home
S 06m 12s 288.1 ft 2,973 ft Data Loss Downlink data connection lost for 2.6 seconds
06m 13s 288.1 ft 2,992 ft
54% Battery at maximum distance
