TedHutcheson
Flight distance : 276168 ft
YOYOMAN Posted at 2018-3-16 07:45
didn't try because I've already sent my M210 to my dealer to repair (GPS-compas issue) .... but I also were interested by mapping with XT and X4S before reading your comment ....
Could you post X4S picture with legs please?
What about the right leg? Which Format / Lens is your XT? Don't you see the right leg?
Hey there YOYOMAN,
So yeah, I got off the phone with my local technical support folks and they too have been issues mapping using the dual gimbal system but only using the X4S camera. Apparently the field of view with that camera specifically is quite wide and it does sit a little closer to the gimbal body. So yes, my service folks are hearing more about this.
Their recommendation(s) however are kind of nonsense. That being,
1. Buy the x5 camera and because it hangs lower and the field of view is a little more narrow this issue becomes a non issue (just spend another 2K?)
2. Put the single gimbal back on (not the ideal solution for us), but after testing seems to work as expected
3. Buy into this shortened landing gear solution of literally cutting the legs in half and removing a small section and joining them back again (apparently there is some kind of pre-designed solution to do this). Cutting the legs? Really? Really? seems like an adhoc solution that will only void your warranty.
All this leads me honestly to think that simply put, DJI has not done enough R&D on this unit for the variety of disciplines we all use these copters for and the types of sensors they're selling to be used on them. At 20K Canadian, I'm not overly impressed at the purchase right now, and don't even get me started on the lack of apps supported by the CS monitor these things come with. What a disappointment.
