Dji spark battery drained in the drone to 8%
2060 18 2018-3-3
Ucel007
Indonesia
Hi,
I just got my spark and flew it to 25%,
After landing it, i thought i had enough to transfer the photo and video to my phone through wifi. And i drained it to 8% while doing so.
After that i left it in the drone for 5 days before i charged the battery again. Before charging i pressed the check button on the battery and it wouldnt blink.
My question is:
1) Did i damage my battery? (all this while the battery is attached to the drone, however when i charged it, it got back to 100%)
2) How do i check if it is damaged? (say if i fly with the battery and got 15-16 min does it mean it is fine?)
2018-3-3
Rustic17
Flight distance : 2733760 ft
Check the volts after tapping the battery icon in the menu.  Each cell should be ~ 4.7 volts after charging and within .1 volt of each other.
2018-3-3
davidmartingraf
Flight distance : 106566408 ft
Chances are the battery discharged during the 5 days and it sounds like you haven't cycled your battery yet. I would try draining it and charging it, also in the DJI GO4 Application you can check to see under Battery how many times your battery has been charged.
2018-3-3
Ucel007
Indonesia
I have just used the battery twice, and didn't read about the minimum I could bring the battery to, so I thought as long as it is 8% it shouldn't be considered over discharged as the spark is intelligent battery...lol.
2018-3-3
Mullheliflier
Flight distance : 12305135 ft
Leave it in the charger for a while. One of my new Spark batteries appeared ‘dead’ the first time I charged it, but the charge sequence lights came on after about a minute. It has been fine since. Fingers crossed you get it going.
2018-3-3
Rustic17
I think you are fine...it will turn itself off when it reaches the minimum voltage.  I have gotten to the point where no lights come on when tested several times.  They have always charged back fine.
2018-3-3
Ucel007
Indonesia
Yeah charged it and plugged into the spark and it started at 95% when fully charged, and checked the other battery I had it starts at 100%, not sure if that is considered damaged.
But no issue in charging, but I would say it is hard to keep a reserve of 20% with the spark as the battery time is already short to begin with...lol
2018-3-3
BeastMaster_101
Flight distance : 1082992 ft
Check the voltage of each cell. They all should be around 4.7 and within not more than .2 of each other
2018-3-3
SkyBug
Flight distance : 487566 ft
Cycle the battery a few times and the cells should balance. As a good rule of thumb, set your low batt warning at 30%. I know it limits the flight but it’s much better on the batteries. I’ve found 4 batteries to be a nice round number
2018-3-3
Ram-UK
Flight distance : 1173045 ft
Check all your batteries’ firmware is updated to the latest and charge them. If the problem persists contact DJI Support.
2018-3-3
Ram-UK
Ucel007 Posted at 2018-3-3 13:55
Shorter battery time........I realised that after a couple of weeks of flying but it was too late. I would have waited and bought a Mavic Pro
2018-3-3
DJI Elektra
Hi, there. When did you buy your spark? If it is under warranty, please contact our support and start a case: http://www.dji.com/support Thanks for your support.
2018-3-5
S-e-ven
Flight distance : 5922034 ft
Thailand
After used UNDER 10%, the batteries are hybernating more ore less directly. To prevent the battery from greater damage. Charge it, all will be ok
2018-3-5
Bayguy69
Flight distance : 944275 ft
Puerto Rico
S-e-ven Posted at 2018-3-5 09:23
How long the battery can be in Hybernation ?
2018-3-16
The Bash's
Bayguy69 Posted at 2018-3-16 22:47
Being that they are Lithium Ion they should be able to hibernate for the industry standard of 2-3 years.  That is also considering that there world is perfect, and that the circuitry in them has no draw while they hibernate.
2018-3-16
S-e-ven
Thailand
DJI is tellin, to "waken 'em up", every 3 month. And recharge them to 60-70%
2018-3-17
DJT_MVSP
Flight distance : 2018645 ft
Singapore
The battery will enter hibernation mode after 6 hours when it's lower than 10% to protect the battery from over discharging
The indicator lights will not light up in hibernation mode
Charging the battery will wake it from hibernation
It is recommended to store the battery between 40-60%
2018-3-17
Bayguy69
Puerto Rico
S-e-ven Posted at 2018-3-17 01:45
Thank you for this very important info...
2018-3-17
Bayguy69
Puerto Rico
DJT_MVSP Posted at 2018-3-17 03:28
Thank you my friend.
2018-3-17
