Crashed my Phantom, dont know how bad it is
1330 14 2015-5-4
kay.schulz
Dear all
I crashed my phantom today. The second I wanted to pick it up after landing it went into "Coming home" mode and went up. I am not experienced enough to react properly.
I was under a tree, the rest you can imagine.
So it seems that most looks ok, one piece opened, as seen in the picture. (not sure if you can see it)
What I am not sure is if some of the while stuff for the gimbal is wrong or right, see second pic. Because two are there, two are not.
I hope you get what I mean. I am totally new, it was my third flight.
Thanks for your help
Regards
kay
broken
broken
unclear
unclear
2015-5-4
tonyray955
As for the compass I would replace it the leg only cost around $20.00 so why risk a $1000.00 drone. The gimbal looks ok not sure what is wrong
2015-5-4
acenothing
Flight distance : 112185 ft
My guess is all is ok.  The open part his the compass.  just sanp the cover back on and it is fine.  Not sure what you are looking at in the 2nd pix..  I think the bird is fine.
2015-5-4
kay.schulz
tonyray955 Posted at 2015-5-4 23:32
As for the compass I would replace it the leg only cost around $20.00 so why risk a $1000.00 drone.  ...
Hi
thanks for the quick reply.
I dont get it how to replace the leg etc.
And where to buy it in Germany....
Thanks again
Kay
2015-5-4
kay.schulz
acenothing Posted at 2015-5-4 23:58
My guess is all is ok.  The open part his the compass.  just sanp the cover back on and it is fine.  ...
so it is usual that not all four corners on the bird look the same. two corners have some sort of rubber connection and the other two havent
2015-5-4
johnwarr
Flight distance : 6467 ft
We need a pic of the whole gimbal, but you should have 4 white rubber mounts, one in each corner, and 2 of them should have the clear plastic pins holding them in.
The compass looks like it should pop back together.
2015-5-4
danrok
Jersey
kay.schulz@gmx. Posted at 2015-5-5 00:11
Hi
You can buy Phantom spares from Heliguy in the UK. I believe they will ship just about anywhere.
Compass is here, for example:
http://www.heliguy.com/spares-an ... vision-compass.html
2015-5-4
kay.schulz
johnwarr@live.c Posted at 2015-5-5 00:23
We need a pic of the whole gimbal, but you should have 4 white rubber mounts, one in each corner, an ...
Hi John
thanks. Here are some pics of the gimbal, one showing with two black arrows, where I see differences which I did not notice before.
arrows included
arrows included
2015-5-4
johnwarr
Thanks, yeah that is how it should be...
2015-5-4
tonyray955
Yeah the lock pins are used to keep the gimbal from falling off and there are only 2 of them in opposite corners like on your.  The compass that danrok linked is not the right one it's for the vision not the vision plus you need part #18
http://www.banggood.com/DJI-Phan ... tatic-p-959677.html
2015-5-4
Axeman This user has been deleted
2015-5-4
kay.schulz
tonyray955 Posted at 2015-5-5 07:00
Yeah the lock pins are used to keep the gimbal from falling off and there are only 2 of them in oppo ...
Thanks
I am a bit worried to order the compass and leg myself and then change it.
Is there any tech bit I have to do? Or is it just a plug to connect the compass to the internal stuff?
To me it looks like the compass is connected with a cable through a hole in the leg. And the compass does not fit through the leg. So it seems to me some hardware fixing to do.
Or can I just unscrew the leg and a new one with a new compass? Or would I have to open the entire copter etc.?
Sorry, if I use hammer and nail my life is in danger, because I am not good at hardware :-(
2015-5-4
davidw1963
I put zip ties though mine where the pins normally go. Kept them loose enougth to provide movement, And I feel they would hold better in a mishap. Ive lost a few of my rubber isolators and I had to get more. The zip ties keep them in place along with the camera. Those pins look like they wouldnt hold in a crash. They seem to separate easyly.
2015-5-5
davidw1963
kay.schulz@gmx. Posted at 2015-5-5 13:25
Thanks
Is there any tec ...
I installed the taller wider gear on mine. I had to notch a hole in the leg for the compass and camera cable. If you remove the top shell cover you will find the compass where its plugged into the module. Just better to notch the leg where the 2 screws are. If your getting a new landing gear, it may come with a compass so you will have to open the top shell anyways to install it. If you get the taller wider gear, then you notch the leg and then tape the compass to the inside part of the leg on the wider gear since it does not have a spot to mount it. I did that with mine with no problems. If you go that route, you will have to cut the compass mount from the old leg and then use it for the mount on the new wider landing gear. You will need very small jewlers scredrivers set to get the top shell off. Remove the outer screws around the motors first then work your way in. The motors themselves DO NOT have to be removed to get the top shell off. Just be sure to install it back in the correct direction since it has the GPS antenna mounted inside the top and it has to be facing right direction to work properely.
2015-5-5
roy
Snap the cover on the compass and test a few times by doin the calibration. If all goes well your home free. If it won't calibrate then replace.
2015-5-5
