Coyut
Flight distance : 2559222 ft
Switzerland
Swedrone Posted at 2018-3-7 07:21
Sure. When you record with the D-Log setting the picture is flat. In post production you apply a LUT to grade it to a certain color. Almost like a filter. On professional field monitors, like the CS is marked as, you can apply the LUT in the monitor and see the end result directly when filming. Without this possibility the screen is very dull with almost no color and contrast when flying. This makes it harder to navigate when flying.
When using EL Mode you can change to a Rec709 look. Which helps already.
But I agree. Adding premade custom LUT's could help in some cases. Atleast for the hdmi out, so the custromer sees a more charmin image ;)
Otherwise, on bigger productions, the folks in the video village can add a look on the customer screen.
