The problem I have is the Pan Axis Motor doesnt Hold position even though the other tilt and Roll motors try to hold as steady as possible. The Pan axis spins loose as if the motor is off and doesnt hold the straight position. This makes the camera spin around freely in the Gimbal while tilt and roll tries to hold steady.
Trying to figure out what causes this issue. I've watched videos and seems that other people have the Gimbal keep the forward position on the Axis when they start up?
DJI Mindy Posted at 2018-3-8 22:19
Hi Ramen, may I know what is the model of you drone? Can you please provide us a short video about the issue for further support? Thank you very much.
DJRamen Posted at 2018-3-9 12:49
I found the Problem. https://forum.dji.com/thread-28288-1-1.html
Basically it was the battery not in tight all the way. Thanks.
Glad to know the issue has been figured out, please let us know if there is any other problem.
