Inspire 1 controller extra file to help update?
963 7 2015-5-5
stayathome29
Flight distance : 52707 ft
Hi all,
Does anyone have the extra file from DJI that is used when your controller will not run the update? I have seen it mentioned doing a google search and I am hoping someone can send it to me.
Thanks,
Scott
2015-5-5
piertex
Flight distance : 370282 ft
Hi,you can try here
https://www.dropbox.com/s/4xfxjp5u043wzc6/gs_ofdm.bin?dl=0
2015-5-5
Ph02on
Flight distance : 75673 ft
Here you go Scott.  I have it on my Google drive.  let me know if the link fails.
https://drive.google.com/file/d/ ... jg/view?usp=sharing
Jason
2015-5-5
joekeantang
   try doing it directly from the gimbal.
1st.Turn on inspire  wait for gimbal to warm up and to do its thing.
2 have the controller ON with the cable plug
3 insert cable to gimbal carefully and quickly.
4. give it a few minutes and then you will probably see it update.
had the same problem with my 2nd controller, support sent me this file. Did not work with USB stick ..
I downloaded from gimbal.
2015-5-5
stayathome29
joekeantang@gma Posted at 2015-5-6 01:31
Thanks for the help
2015-5-7
JKT
Did it work?
2015-5-7
stayathome29
No nothing I did was able to get the controller to update, had them send me an rma and sending it in Monday.
2015-5-10
stclassic01
I'm having the same problem I can not load the new firmware. DJI sent me that file and it loaded ok but when I put in the new firmware it gos so long than fails. When I checked the txt files the results txt would say rc failed reload firmware again. But in the log txt it would say success. Everything seems to work on the bench and on the app but I have no video feed. I can take pictures and videos but I can not view them or see what the camera sees on the DJI app.
I'm afraid I will have to send my controller in which probably means I won't be able to fly my I1 all summer.
2015-5-10
