TEST: Just How Precise is Mavic's Percision Landing??
851 11 2018-3-19
fans825c0532
Flight distance : 341355 ft
Hello , this is my test video of how percise Mavic pro's percision landing is.
Hope you enjoy!
2018-3-19
HedgeTrimmer
On large concrete area, no landing pad, with an actual emergency RTH - I found Mavic Pro P to have very precise landing.  Mavic Pro P appeared to land same place and pointing same direction as it took off from.
2018-3-19
Locoman
Flight distance : 748675 ft
My MP will land by it's self with in a couple of inches from where it took off from.
2018-3-19
fans825c0532
HedgeTrimmer Posted at 2018-3-19 22:00
That is why I found it to be quite impressive. To find it's way back to almost exactly the same spot!
2018-3-20
fans825c0532
Locoman Posted at 2018-3-19 22:40
that is what I found out in this test! pretty impressed!
2018-3-20
Locoman
In the beginning I used RTH a lot, just to make sure it worked. This winter not so much because I took off from my deck, under a canopy of trees and could not have it just drop straight down, so had to fauns a through the trees landing. Which is good experience for manual flying. Now I will use it every once in a while but like the challenge of manual landing. Still with do the precision take off though, so incase of trouble, the home point is locked and loaded.
2018-3-20
A CW
Flight distance : 13926112 ft
Within an inch or two - on the very rare occasions I use it.
2018-3-20
fans825c0532
Locoman Posted at 2018-3-20 22:13
true..
i try not ti use rth ever.
i always try to remember to check that home is recorded.
and i usually hand launch and catch
2018-3-21
fans825c0532
A CW Posted at 2018-3-20 22:36
yahh same here.
but it is good to know that the mavic can have this accuracy if needed!,
2018-3-21
A CW
fans825c0532 Posted at 2018-3-21 10:10
yahh same here.
For sure - amazing tech
2018-3-21
B1houdini
Flight distance : 927927 ft
99% of the time my MP has hit the mark using RTH and the precise landing option.
There has been a few occasions it missed the mark by 10 feet.. Had to take control when it was about to land.
I found in those  case if I recalibrate the compass it will RTH and will land exactly where it took off from.
I always check the status of the compass and IMU before flying. I have no explanation why it sometimes is off when it does RTH.
2018-3-21
dwainwayne28
Flight distance : 583323 ft
Trinidad and Tobago
It's usually very accruate, however, it has missed the landings a couple times by about 7-10 feet.
2018-3-21
