Height Sensor
946 10 2018-3-22
DeFuanz
Recently picked up another spark from amazon and it seems that ive noticed two things, 1. When its about 40 (example height) feet up the height will change between the actual height and about 5 ft. Not really sure why but i think that when i hold the throttle down to come closer to the ground it thinks the ground is there and autolands? not really sure but thats the second thing is sometimes i stop throttling up itll rise for a few seconds more and throttle down itll ocassionally start to land. Any one have this happen to them? great gps and wifi signal every time too.
2018-3-22
Arcobaleno Reborn
Philippines
try another location or multple area if it happens on other areas.   To test for interferance also try updating your firmware to the latest and uninstall reinstall the application. Also try using another phone and tablet
2018-3-22
DeFuanz
Arcobaleno Reborn Posted at 2018-3-22 07:00
cool, Thanks. Definitely wasn't interference because its done it in multiple locations. It seems like its just a fault with the bottom sensor somehow. I also read somewhere that some of the sparks land if you push the throttle all the way down? i updated today again so ill see if theres another update later that didnt show and ill try uninstalling  and reinstalling the app.
2018-3-22
Firehawk989
Flight distance : 198904 ft
Make sure there's nothing on the sensor. Plastic film, dirt, fingerprints, etc.
2018-3-22
Firehawk989
If it all looks good I would return it for replacement as that's not normal behavior.
2018-3-22
Arcobaleno Reborn
Philippines
Calibrate the vision sensor using dji assistant 2
2018-3-22
DeFuanz
Firehawk989 Posted at 2018-3-22 09:10
ill definitely check that out on tomorrows flight! would that effect the landing? thanks!
2018-3-22
DeFuanz
Arcobaleno Reborn Posted at 2018-3-22 11:11
ill check into that! thanks!
2018-3-22
davidmartingraf
Flight distance : 106566408 ft
Are you flying above or below sea level?
2018-3-22
Firehawk989
DeFuanz Posted at 2018-3-22 19:45
Yes, if there is any junk on the sensor or if you forget to remove the plastic film it's shipped with, it confuses the sensor. Fog or heavy snow can also confuse it and potentially cause it to continuously rise.
2018-3-23
DJI Susan
Hey DeFuanz, may I know what's the current status? Have you tested the performance after cleaning the sensors?
2018-3-25
