Flight Status Query. Am I really in P-OPTI?
637 6 2018-3-28
fansef1f9947
Hello all. I have a simple question that has been confusing me.
I have been flying my Phantom 3 Advanced for a few weeks now. I have noticed when I click “safe to fly” to bring up the aircraft status page, it always shows the aircraft to be in P-OPTI but this is always when the aircraft is showing on the main screen as P-GPS? Is this right? I would think that the 2 should always be the same?
Many help or information is appreciated. Thank you.
2018-3-28
Eric13
Flight distance : 13982031 ft
Do you get the P-Opti status upon start up?
I get P-Opti  upon start up only while the GPS is searching for satellites.
After that it changes to P-GPS.
2018-3-28
fansef1f9947
Hi eric, yes I do. Upon start up I get p-opti in the flight screen, but then it turns to p-gps after few seconds. I then check the aircraft status before I take off and it always says p-opti but the flight screen still says p-gps.
2018-3-28
Eric13
fansef1f9947 Posted at 2018-3-28 11:22
You are good. Normal behaviour.
Just don't be too impatient after powering up your drone. And don't move it after you did so.
Once you power up the drone/RC/app, let the system settle itself.
It may take more than a minute till take off status is good.
2018-3-28
Labroides
Flight distance : 9991457 ft
Next time, watch the satellite count and see how that affects things.
P-Opti is telling you that you do not have enough sats for P-GPS but the VPS system should be able to hold the Phantom in stable flight (if the ground has a suitable pattern/texture and lighting is good and you are within VPS range - 1-10 metres altitude).
When enough sats are locked then you get P-GPS.
2018-3-28
fansef1f9947
Ok thanks very much Eric. Il try that tomorrow. The order I do things (if I’m wrong please say).
1. Plug usb from RC to iPad.
2. Switch on RC
3. Open dji app
4. Switch on the phantom.
Maybe I’m too quick in checking the aircraft status after connecting to the aircraft?
2018-3-28
DJI Thor
Flight distance : 13602 ft
fansef1f9947 Posted at 2018-3-28 13:13
This sequence is good. For your main concern, the status of the aircraft status and the transmission interface should be the same, however, sometimes if there is a delay or the status has not been refreshed, they could be different. You can try to close the window, wait for a while and open again.
2018-3-28
