DJI Assistant won't recognise my Mavic Pro OR Mavic Air
1899 13 2018-3-30
fans82c07b6b
Flight distance : 3291 ft
HI,
Hoping someone can help with getting my Mavic Pro and Mavic Air connected to my PC via DJI Assistant (i'm using the latest version 1.2.3)
Have installed, uninstalled etc but still comes up with wanting to connect to an Inspire, actually can't even get passed past the main screen let alone it recognising the drones..
2018-3-30
Bob Brown
Flight distance : 4209662 ft
Try a different usb cable and if that doesnt work try a different computer.  Also POWER ON the drone when it is connected via usb. Be sure the gimble cover is removed.
Your welcome.
2018-3-30
Kevjones1959
Flight distance : 61932 ft
South Africa
So help me here, BOTH aircraft wont connect ??
2018-3-30
Wachtberger
Flight distance : 261509 ft
If it is a windows PC you may try with this driver: https://drive.google.com/file/d/ ... FE/view?usp=sharing
2018-3-30
fans82c07b6b
Thanks for the help so far, yes - Win 10 and I will try a different cable and the different driver / software.
Re both drones, yes, that's correct, can't get past the screen as per the image above
Appreciate your help in advance
2018-3-30
Simmo1
Flight distance : 1624 ft
Try searching for DJI unsigned drivers , see if that helps you?
2018-3-30
Wachtberger
fans82c07b6b Posted at 2018-3-30 02:47
During installation you need to confirm that you allow installation of unsigned drivers.
2018-3-30
Kevjones1959
South Africa
Look generally speaking windows 10 is quite good at getting the right drivers. As soon as I plugged the aircraft into the USB port on the Laptop it went and fetched drivers. They work fine. Try and use the cable that came with the Mavic Air USB -C into the back of the air and USB into the PC, switch on the Air and the Controller and get the Air and controller to connect. Then open DJI-Assist on the PC.
2018-3-30
fans82c07b6b
Hey all,
All good, I think the software helped, connected and working as it should
Thanks a bunch
2018-3-30
Wachtberger
fans82c07b6b Posted at 2018-3-30 03:13
Hey all,
Great to hear!
2018-3-30
Simmo1
Wachtberger Posted at 2018-3-30 02:57
Wachtberger is correct, however there have been instances where that doesn't work. (me for example!)
I had to get into some deep dark place in the PC and ask it to permit 'unsigned Drivers' and all of a sudden, the Assistant worked. Searching Google for Unsigned drivers will get ya going.
I have seen other work arounds with people deleting stuff in Device manager but I dunno!
2018-3-30
fans82c07b6b
Thanks Simmo1, i may do that as a precaution anyway
2018-3-30
Kevjones1959
South Africa
As they say here "lekker man, lekker"  .. nice man nice.
2018-3-30
DJI Diana
Flight distance : 2408 ft
Hey all,
Hi, I'm glad to know that you have solved the issue and everything turns out to be great. Hope you have a good time on flying the drone.
2018-3-30
