spark not scan qr code and wi fi
6582 13 2018-4-1
hitman88
Flight distance : 4564 ft
Cyprus
spark not scan qr code and wi fi plese help
2018-4-1
flydav
Flight distance : 184226 ft
You're not giving any details about the device you're using...iPhone? Android? However you can activate the aircraft without necessarily scanning the code just put the password you find either on the back of the aircraft or on the back of the RC. FOLLOW THE STEP BY STEP INSTRUCTIONS on the device, or manual, or youtube.
2018-4-1
hitman88
Cyprus
flydav Posted at 2018-4-1 01:09
i have done it it not working
2018-4-1
Ani
Flight distance : 1148 ft
India
Your product might have different username and password on box and spark.
Just remove the battery from spark and then note down the credentials that are mentioned on a sticker on spark battery compartment and then try inputting those.
It will connect well.
2018-4-1
hitman88
Cyprus
Ani Posted at 2018-4-1 02:40
it is same
2018-4-1
hitman88
Cyprus
2018-4-1
DJI Elektra
Hi, did you try to use IOS device to search the wifi of spark or RC? Or you can try to reset wifi.
2018-4-1
hitman88
Cyprus
DJI Elektra Posted at 2018-4-1 03:05
https://www.youtube.com/watch?v=MwAVJSbO8Ek&t=2s
yes ı try ıos and rc ıt dıd not work
2018-4-1
hitman88
Cyprus
hitman88 Posted at 2018-4-1 03:08
im reseing wifi
2018-4-1
DJI Elektra
Did you solve the problem? Please try to flash the firmware of spark. If the problem remains, please contact our support and start a case: http://www.dji.com/support
2018-4-1
hitman88
Cyprus
DJI Elektra Posted at 2018-4-1 22:06
https://www.youtube.com/watch?v=1Psa4hAImKw&t=1s
yes I have thanks for the help
2018-4-8
Brookworth22
New aircraft. No internet connection message on both aircraft and remote on both iPhone or iPad both of which see WiFi but unable to connect. Unable to get past this!!
2018-4-8
flydav
Brookworth22 Posted at 2018-4-8 08:02
So if you go in your iPhone/ipad wifi settings do you see the 2 Spark wifi networks? I mean 1 network is generated by the spark when you DON'T use the RC. The other is generated when you DO use the RC. Make sure you select the right wifi network and the right password.
2018-4-8
DJI Elektra
hitman88 Posted at 2018-4-8 07:24
You are welcome. Have a nice day!
2018-4-8
