S-e-ven
Flight distance : 5922034 ft
Thailand
Your analyzer shows you the RC to Phone wifi, 2.4
Your phone does not see the Spark wifi, if the Spark is connected to a RC!
The App shows the RC to AC connection, 5.8
Which works out, you have only this 2 Wifis to work with. If you use the phone in wifi, the RC HAS to use both wifis, one for the AC (5.8 right now), one for the phone (2.4)
If you would use a OTG cable, you won't see any Spark/RC wifi.
just in the app the chosen band from RC to Spark
And again, but the last time:
You are happy with wifi from Phone to RC: Keep the 4.2.8
You wanna use cable: Uninstall 4.2.8 and test the 4.1.15 and 4.1.14 versions on apk mirror
Maybe your last 4.1.15 installation got corrupted.
Set it up, new, try if the switching happens again.
And make sure, your phones wifi is OFF, when having the RC powered on.
Like Vyborny83 wrote, you may had a cabel between RC and Phone, but the connection was still wifi.
And with RC to AC at 2.4, only the 5.8 could be used to the phone.
That is why I wrote to check with the analyzer, if it is happening again: You see the RC wifi, you are not otg connected!
