Do you have to wait to charge RC??
SparksBird
Flight distance : 10731690 ft
Do you have to wait to charge your RC say 30 minutes after flight similarily how you have to with the drone batteries?  I know the reason being is to let the battery cool down but am sure that the drone battery is much warmer than the RC right after flight so wondering if same applies to the RC.  Thanks
2018-4-8
Suren
Flight distance : 13498560 ft
South Africa
I dont wait to charge Rc. Normally my batteries have the led 4 blinking telling me its to hot to start charge but the Rc charges imediatly even after flying 3 batteries full down to 20%
2018-4-8
SparksBird
Suren Posted at 2018-4-8 10:57
Sweet thanks for the reply I figured as much but just wanted to be sure.  I figure the battery in the RC does not really get hot so should not be an issue but wanted to be sure
2018-4-8
Suren
South Africa
SparksBird Posted at 2018-4-8 11:01
Not really because the Rc has a built in fan that comes on when getting hot
2018-4-8
Landbo
Flight distance : 502792 ft
Denmark
It's always best to wait for a battery to cool down completely after use. The hotter a battery is in use / charge, the shorter the life span. It is a fact no one can talk his way out of.
I am waiting one hour before I start to charge a battery after use.
Regards Leif.
2018-4-8
hallmark007
Flight distance : 9827923 ft
You won’t have any problem charging your RC , it is air cooled charging won’t have any effect, RC very seldom get hot.
2018-4-8
DJI Diana
Flight distance : 2408 ft
Hi there, if the RC is too hot after use, then it is recommended to wait for a while until it cools down. Thanks!
2018-4-8
SparksBird
DJI Diana Posted at 2018-4-8 17:58
Hi DJI Diana and thanks for your response.  But how will you know if it is too hot, will you notice by the touch enough to know if it is or not?  I mean isn't the battery far enough inside that you really cannot tell the temperature of the battery?  It is a different story with the craft battery and can easily tell how warm it is.
2018-4-8
