high altitude is negative
815 14 2018-4-12
Ferry76
Flight distance : 151224 ft
My spark drone is 10 meter high and in DJI Go is the high attitude 2,5 meter.
When het is 1,5 meter high in DJI Go is the high altitude - 2,5 meter
If i command to down many times i received the warning fot automatic landing.
What is wrong? Al my settings are unchanged.
2018-4-12
Firehawk989
Flight distance : 198904 ft
Make sure you don't have any dirt, fingerprints, marks, plastic film, etc. on the sensors.
2018-4-12
DJI Elektra
Hi, did you try to reboot your drone and fly again? Please make sure that you did not fly your drone lower than the take off altitude. Please keep us updated, thanks.
2018-4-12
Ferry76
DJI Elektra Posted at 2018-4-12 22:06
Yes reboot  many times didn’t help
2018-4-12
Ferry76
Firehawk989 Posted at 2018-4-12 09:21
Everything is very clean.
2018-4-12
S.J
Flight distance : 322454 ft
Kuwait
start your drone while placing the SPARK in the ground itself rather than in your palm although it should work otherwise.
2018-4-13
Ferry76
S.J Posted at 2018-4-13 00:12
I place always the drone on the ground itself before flying, never from my Palm or any other place above the ground.
2018-4-13
S.J
Kuwait
Ferry76 Posted at 2018-4-13 00:43
I mean while you switch ON the drone, place first the drone on the ground and switch ON the drone from a ground point.
2018-4-13
DJI Elektra
In your case, please sync the flight records with error phenomenon and tell me your DJI Account for further check.
2018-4-13
Ferry76
S.J Posted at 2018-4-13 00:46
I know that but same issue
2018-4-17
Ferry76
DJI Elektra Posted at 2018-4-13 02:50
DJI account is Ferry Lankreijer
2018-4-17
Ferry76
In the DJI Go 4 app the H N/^ metric begins  always on: H0,0m in the color red is that normal? When i’m flying the color is white above 1,3 m en begin on 0 m
2018-4-17
Ferry76
Anybody else for a solution?
2018-4-28
wd5gnr
Flight distance : 3196 ft
I have the same problem and have not found a solution. It does occasionally show a very low positive number (like 20 feet).
2018-4-28
Ferry76
Ok, i’m not the only one, is this a defect or have DJI a solution for this?
I have the DJI Care Refresh.
2018-4-28
