Kevin36
Flight distance : 356476 ft
South Africa
Aardvark Posted at 2018-4-17 14:40
An IMU calibration will have no bearing on the compass at all. I assume that the legs are unfolded when you check readings and do the compass calibration ?
Under normal circumstances the compass only needs calibration when prompted by system.
Here is some context, DJI Support responded as per below;
Dear Kevin,
Thank you for contacting DJI.
We are so sorry to hear what happened to your unit. We do understand how you feel and for the inconvenience you are experiencing right now.
With regarding this issue, let us attempt to fix this by following the steps below:
• Please ensure that your firmware us updated, perform a firmware update if prompted by the app.
• Please check the antenna position of your RC.
• Please Re-link your Aircraft and RC.
• Please calibrate your aircraft's system sensors agian(IMU and Compass)
• Please attempt to fly the aircraft on a different location free from interference (ie trees, buildings, power grids, airports, communication towers, metallic structures and facilities that emit electromagnetic waves).
Kindly send us a feedback if the process above is a success or send us a screenshot if the issue is still present.
Thank you,
You will receive an email survey two days after this email if not responded. If you happen to be away and won’t be able to answer this email timely, please disregard the survey and reply to us directly.
Best Regards,
DJI Technical Support
Website: www.dji.com/support
So I did as they asked, I checked all firmware was updated, I ensured the antennas were at 45degrees, I relinked AC and RC, I recalibrated the IMU and Compass (or at least I tried) and I tried a different location.
Yes legs are folded with a IMU calibration and unfolded with a Compass calibration. The RC is on the ground while I do the calibration dance. My first MP did not display any of this, so this is something new with both of these models.
